PIX515 VPN tunnel problem
I have PIX515 and terminated 2 ISP's in interface Eth0 & Eth2
I have created 2 IPSec tunnels already b/w local & remote office thro' Eth0 and are up.
I wanted to create a tunnel b/w local & remote office on second interface Eth2 but the tunnel is not coming up.
ISAKMP is enabled on both interfaces.
interface Ethernet0
nameif ISP1
security-level 0
ip address xxxxx 255.255.255.128
interface Ethernet2
nameif ISP2
security-level 4
Both local & remote office has got PIX515.
Cisco PIX Security Appliance Software Version 7.0(2)
Re: PIX515 VPN tunnel problem
Mate,
Not quite sure that the information that you have provided is enough to help us help you :-); I would say that you need to check the following:
- ISP is not blocking any ISAKMP and/or ESP traffic
- Your Internet gateway is not filtering any of the IPSec freamework protocols/ports
I would recommend that you remove any ACL on any router on the way till you get connectivity and then re-apply everything again.
Hope this might click a thought somehow ...
Cheers.
Make sure your ISAKMP keys and IPSEC policy match on both PIXes.
Once that is done, make sure you verify:
show ipsec sa
show isakmp sa
All you should need to do to bring up the tunnel is generate "interesting traffic"
You will need to generate new RSA key
ca generate rsa key 512
ca save all
Good luck.
I have cisco PIX 515E with failover.
I need to configure IPSEC with another router.please let me know the steps & procudure & steps for configuration.Please find the config.Please find the attach file
Moorthy.
try looking here for a walkthough
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800ab518.shtml
it goes though the basic steps, also if you search cco there are several good guides on setting up basic vpns
104
