Hi Joseph,
You'll see this state when a connection is closed because its corresponding parent connection has closed.
As an example, you might see this connection state on a FTP data channel (child flow) after the FTP control channel (parent flow) has been closed. In this example, the data channel is considered the child flow because it was opened at the request of the control channel.
Hope that helps.
-Mike
