Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Plase advice me for NAT on Cisco ASA5520
Please advice me for NAT on Cisco ASA5520.
i want to nat on asa for any user form internet can access SIP server via
203.145.22.121:6060 to 192.168.0.10:5060 and 192.168.0.11:5061
and from internet can access WEB server via 203.145.22.121:8888 to 192.168.1.10:8880
have any way i create loadbalance on asa5520 to user sip server
thank you so much.
Re: Plase advice me for NAT on Cisco ASA5520
for nat something like this:
sip:
static (inside,outside) tcp 203.145.22.121 6060 192.168.0.10 5060 netmask 255.255.255.255
don't really know but don't think loadbalancing is possible.
web:
static (inside,outside) tcp 203.145.22.121 8888 192.168.1.10 8880 netmask 255.255.255.255
the alcs:
access-list outside_access_in extended permit tcp any 203.145.22.121 255.255.255.255 eq 6060
access-list outside_access_in extended permit tcp any 203.145.22.121 255.255.255.255 eq 8888
the interface:
access-group outside_access_in in interface outside
hope thats correct and helps
regards,
juergen
Hi, double check your web static nat as 192.168.1.10 is in dmz interface not inside.
rgds
Jorge
right, should be (dmz,outside)
For your load balancing issue, can you do a cluster for the two servers so that there is one Virtual IP and one port to listen on/
Satya
177
