Point Public Ip to Two Local IP
Hi, In asa by natting we can map one single IP to Local IP. Is it possible that we cud map one public IP into two local IP of Servers and set the priority if Ist server gets down (Ist Loacl IP) then by default the query from outside to be forward into second one IP.
1 REPLY
Re: Point Public Ip to Two Local IP
Hi Ray
You can forward the 2 different ports of single public IP to two Local IPs. But you can not forward the same port to two different servers.
What you want to achieve is a kind of NLB (Network Load Balancing)
153
