Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Policing Traffic Does Not Work
I'm trying to use qos to police traffic where a certain host should not go above 5Mpbs at any time and if the traffic is exceded it should be dropped.
I have trying to play around with the below but the host machine can still access the full bandwidth.
class-map laptop
match access-list laptop_acl
access-list laptop_acl extended permit ip host 192.168.3.10 any
policy-map laptop_sp
class laptop
  police input 5000000
  police output 5000000
service-policy laptop_sp interface outside
Everyone's tags (3)
Hello John,
Try it like this
class laptop
police output 50000 conform-action transmit exceed-action drop
police input  50000 conform-action transmit exceed-action drop
Afterwards do a clear local-host 192.168.3.10
Julio
CSC is a free support community, rate all the posts of our team,
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Community Member
Hi Julio,
Thank you.
The above seems to rate the traffic, but for some reason when I do a speed test the traffic gets policed but after a while of testing I am unable to connect to the internet and connect to the firewall via ssh.  All network access seems to have stopped I have to reload the firewall to get access back?
Hello John,
Of course that should rate it!
Now why you got unable to connect to the internet or even the ASA, that is completely different.
On the ACL you have there you are only including one PC, correct?
Are you able to ping the ASA after you get disconnected?
Rate the helpful posts
Julio Carvajal
Community Member
Re: Policing Traffic Does Not Work
No not able to ping the ASA.
For some reason after the police is applied and when going through a speed test you can see the ASA policing the traffic but during the policing the speed test hangs there and network traffic grind to a halt.
It like the ASA has somehow stopped the host to transmit any data because it has gone past the police rate or tried to burst.
Community Member
I've added thoses commands but when i do a:
firewall(config-pmap-c)# show service-policy police
Interface inside:
  Service-policy: speed_limit
    Class-map: rate_limit
      Input police Interface inside:
        cir 3670000 bps, bc 114687 bytes
        conformed 36029 packets, 21519175 bytes; actions:  drop
        exceeded 536 packets, 752429 bytes; actions:  drop
        conformed 117104 bps, exceed 392 bps
      Output police Interface inside:
        conformed 0 packets, 0 bytes; actions:  drop
        exceeded 0 packets, 0 bytes; actions:  drop
        conformed 0 bps, exceed 0 bps
Interface outside:
      Input police Interface VM:
      Output police Interface VM:
        conformed 5097 packets, 1544222 bytes; actions:  drop
        conformed 17264 bps, exceed 0 bps
I used the 'conform-action transmit exceed-action drop'  but the conformed packets shows drop when it should show transmit.
Community Member
Anybody please?
Hi Bro
If you need me to help you, I need you to paste your complete show running-config here. This is because your show service-policy police output doesn't match the commands you've typed.
Shown below is exactly what I've done in my lab using Cisco ASA 5510 v8.0.2, and the output is good. I don't think the problem that you're having is a software bug. I believe you've typed in the wrong parameters in your show running-config :-)
class-map rate_limit
policy-map speed_limit
class rate_limit
  police output 3670000 114687 conform-action transmit exceed-action drop
  police input 3670000 114687 conform-action transmit exceed-action drop
service-policy speed_limit interface dmz
FW01# show service-policy police
Interface dmz:
      Input police Interface dmz:
        conformed 0 packets, 0 bytes; actions:  trasnmit
      Output police Interface dmz:
P/S: Personally, I believe you've used the keyword "drop" in the 'conform-action drop exceed-action drop', but I stand corrected
Note: If you think my comment is useful, please do rate them nicely :-)
Warm regards, Ramraj Sivagnanam Sivajanam Technical Specialist/Service Delivery Manager – Managed Service Department
Community Member
trasnmit? I wonder did you mispell that or did cisco?  On my 8.2(1) it says conformed...drop in the show service-policy even though I told it transmit and it appears transmit is the default since the config prunes that.  It's not working anyway appears buggy I think I need to upgrade...
1407
