Port 5061 Issue on FWSM
Rick Morris
Level 6
Level 6
We are running a FWSM and have created ACL's for a new Lync install.  One of the rules needs to have port 5061 access from any source to our front edge server for communication.  When looking at the logs I see a hit on the ACL but nothing ever actually connects.
One possible issue I see is possibly in the inspect:
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect sqlnet
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect pptp
class class_sip_tcp
  inspect sip
In the inspect sip this is only for port 5060.  How do I set this up to allow port 5061?
mirober2
Hi Rick,
Assuming you want the inspection to process both TCP/5060 and TCP/5061, the config would look like this (otherwise adjust the 'match' command in the class-map accordingly):
class-map class_sip_tcp
   match port tcp range 5060 5061
   class class_sip_tcp
     inspect sip
service-policy global_policy global
Keep in mind, though, that the FWSM's inspection engine cannot process encrypted traffic. So if TCP/5061 is encrypted via TLS you don't want to enable the inspection for this traffic.
-Mike
