Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Port 80 not being forwarded
Okay, I've been through this config 100 times and can't figure out why it's not working.  I have a notes server on the inside that will answer on port 80 from the internal lan but not through the firewall.  Notes box is 172.29.70.230, outside is 108.162.28.83.  Is there something I'm missing.  I can ping the outside address just can't get to the web page.
ASA Version 8.2(5)
hostname HCKASA01
enable password 1fek2L2MjEGCSJe1 encrypted
passwd 1fek2L2MjEGCSJe1 encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
speed 100
duplex full
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
nameif inside
security-level 100
ip address 172.29.70.220 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 108.162.28.82 255.255.255.248
ftp mode passive
access-list acl_out extended permit icmp any any
access-list acl_out extended permit tcp any host 108.162.28.83 eq lotusnotes
access-list acl_out extended permit tcp any host 108.162.28.83 eq www
access-list acl_out extended permit tcp any host 108.162.28.83 eq https
pager lines 24
logging monitor debugging
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 172.29.70.0 255.255.255.0
static (inside,outside) 108.162.28.83 172.29.70.230 netmask 255.255.255.255
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 108.162.28.81 1
route inside 172.27.0.0 255.255.0.0 172.29.70.222 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
ssh version 2
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username comms password eiE0IOA.TSSAU935 encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
1 REPLY
Configuration looks good you should check ACL hit count while hitting from outside. Please setup some capture on inside interface and post here.
Ajay
270
