Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Port Forwarding ASA5505
I have an ASA5505 configured for Remote VPN connection. I am adding an IP phone server that will allow remote IP phones to connect to the internal phone system. I need to Port Forward port 59002 to an internal IP address. Is there an easy way to do this? Thanks, Kevin
Re: Port Forwarding ASA5505
Kevin,
Is the IP phone software or hardware based?
Community Member
Andrew,
I believe it is hardware based because I have an actual phone as a remote and a computer inside my network. It is an ESI 50 system.
Kevin
Just add an entry to the acl allowing any remote access to the NAT ip using a desintaiton TCP/UDP port required.
Community Member
Can you give me the entry for that? I have added a couple of access-list commands and static commands to the configuration. I can see the static entry in the NAT using ASDM showing the port on the outside and the IP on the inside but it still does not work.
you just need to allow the port on the ACL on your remote user policy group.
see this http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080641a52.shtml
Community Member
Francisco,
This remote phone does not use the remote VPN connection. I think it just uses our public IP and port. With the port forwarded to the IP of the ESI computer on the inside of the network.
Kevin
Static (INSIDE,OUTSIDE) tcp interface 59002 59002
Access-list permit tcp/udp eq 59002
I just gave you the commands
Community Member
I see that now thanks! Please forgive me, I am not an IT professional, just a small business owner trying to survive. Can you give me an example of the and the . I know what my public IP is. Thanks!
Access-list ACL_OUT permit tcp/udp ANY eq 59002
access-group ACL_OUT in interface OUTSIDE.
If you hace any problem please send me the
show run access-group
show access-list
Community Member
When I type in the access-list command, I get the error Invalid Hostname with the indication on the "e" of eq.
Community Member
Success!! I added the word "host" before the public IP and then followed the rest of the commands. The phone works! Thanks!!!!
Very Welcome have a good one
941
