Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
port forwarding cisco 1811
im trying to creat a port for a app on a desktop computer. the computer is the only computer pluged in to vlan1 ip address 192.168.5.2.
ip trying to open port 32669. i thought the nat to the inside would do it but when i try and open the app it still says thats blocked. Thanks
Current configuration : 1919 bytes
version 12.4
hostname BrownTown
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging console
no aaa new-model
clock timezone EST -5
dot11 syslog
ip source-route
ip dhcp pool 0
   import all
   network 192.168.5.0 255.255.255.0
   dns-server 8.8.8.8 8.8.4.4
   default-router 192.168.5.1
   lease 31
ip dhcp pool 1
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   lease 31
ip cef
no ipv6 cef
archive
log config
  hidekeys
interface FastEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface FastEthernet1
ip nat inside
load-interval 30
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
ip address 192.168.5.1 255.255.255.0
ip nat inside
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet0 overload
ip nat inside source static udp 192.168.5.2 32669 interface FastEthernet0 32669
ip nat inside source static tcp 192.168.5.2 32669 interface FastEthernet0 32669
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
end
Everyone's tags (1)
Hello Jason,
That actually should do it, you do not have any filtering configured on this router.
My recommendation:
Make sure the firewall is disabled on the PC and also if running any antivirus disabled and test cause traffic should be reaching your box right now.,
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Jason,
Are u still having the issue
Jcarvaja
Julio Carvajal
Hey Julio,
I ended up changing it around a little bit too changed the port it used and put it on the switch insted of the vlan
ip nat inside source static tcp 192.168.1.6 13531 68.204.31.25 13531 extendable
ip nat inside source static udp 192.168.1.6 13531 68.204.31.25 13531 extendable
my app still is telling me the port is blocked but every thing else is saying its good
Hello Jason,
Just for test purposes do:
ip access-list extended out_in
permit tcp any host 68.204.31.25 eq 13531
permit ip any any
int FastEthernet0
ip access-group out_in in
Then try to connect and share the output of
show access-list out_in
Jcarvaja
Julio Carvajal
Hey Julio,
dose this look good?
BrownTown# show access-list out_in
Extended IP access list out_in
    10 permit tcp any host 68.204.31.25 eq 13531 (1895 matches)
    20 permit ip any any (2595177 matches)
thanks
It does look good which means traffic is getting to the router.
Now lets do the followng
ip access-list extended in_out
permit tcp any host 192.168.5.2 eq 13531
permit ip any any
int vlan 1
ip access-group in_out out
Then connect and provide us
show ip access-list in_out
Jcarvaja
Julio Carvajal
Hey Julio, i changed it around a little bit moved the computer over to the gi switch on the fast 1 port so id have gig on the interlan.  i modified your comands to match let me know what you think. looks good to me. but im not home right now so i cant test the app on the computer ill let you know once i do
bandwidth 60000
ip address dhcp
ip nat outside
load-interval 30
duplex auto
speed auto
ip nat inside
load-interval 30
duplex auto
speed auto
permit tcp any host 192.168.1.6 eq 13531
permit ip any any
permit ip any any
BrownTown#sho ip access-lists in_out
Extended IP access list in_out
    10 permit tcp any host 192.168.1.6 eq 13531 (175 matches)
    20 permit ip any any (5354 matches)
BrownTown#sho ip access-lists out_in
    10 permit tcp any host 68.204.31.25 eq 13531 (162906 matches)
    20 permit ip any any (6543236 matches)
Hello Jason,
We let us know that traffic is going to the sever.
Can you run wireshark on the PC and make sure is replying to the outside user?
Jcarvaja
Julio Carvajal
Re: port forwarding cisco 1811
Hey Julio,
looks like it is working app is running fine but its still saying that the port might be blocked. .
but iv also tryed after removing the access list and get the same resultes in wire shark
Heck i mean i just removed the ip nat statemet and it still looks like its passing
bandwidth 60000
ip address dhcp
ip nat outside
load-interval 30
duplex auto
speed auto
ip nat inside
load-interval 30
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
ip nat inside source static tcp 192.168.1.129 1788 68.204.31.25 1788 extendable
ip nat inside source static udp 192.168.1.129 1788 68.204.31.25 1788 extendable
permit udp any host 192.168.1.6 eq 13531
permit ip any any
permit udp any host 68.204.31.25 eq 13531
permit ip any any
1027
