You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Port Forwarding help for DVR system
Hello Folks,
I have a Cisco ASA 5505 and I just setup a DVR system at our office. Everything works fine inside where we can go directly to the IP address 10.11.15.90, but we would like to also be able to access it from the outside as well.
I am not to familiar on how to do this and would greatly appreciate some help.
Device IP is 10.11.15.90
Port is 6802
Please let me know if any additional information is required.
  • Firewalling
Hall of Fame Super Blue
Additional information required -
1) what public IP do you want to present this as ie. the public IP on the outside interface or a separate public IP ?
2) what version of code are you running on your ASA
Jon
Re: Port Forwarding help for DVR system
Hi Jon,
1.) for the public ip just use x.x.x.x and I will put in the correct information.
2.)Currently running ASA Version 8.4(1)
Thanks for the help.
Just to not to repeat what's been said million times, if you have newer 8.4+ version of ASA, this link should explain everything to you, begining from part where website is made available to the outside users. Replace webserver with your DVR and port 80 with port 6802:
http://rowell.dionicio.net/configuring-nat-for-a-public-server-using-same-outside-interface/
424
