06-01-2012 10:27 AM - edited 03-11-2019 04:14 PM
Greetins All - hopefullly you can help me. I'm trying to port forward some ports to my internal mail server, namely smtp , www and http/https. It looks like nat does work but its possible the firewall blocks it.
-cus-fw-01(config)# show nat
Auto NAT Policies (Section 2)
1 (inside) to (outside) source static mailserver interface service tcp smtp smtp
translate_hits = 1, untranslate_hits = 6 <------- this happens when i try to telnet <mydomain.com> 25 , from an outside host
2 (inside) to (outside) source dynamic obj-10.10.10.0 interface
translate_hits = 8435, untranslate_hits = 673
my access list
elg-cus-fw-01(config)# show access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
alert-interval 300
access-list outside_access_in; 4 elements; name hash: 0x6892a938
access-list outside_access_in line 1 extended permit tcp any object mailserver eq smtp (hitcnt=0) 0x029b8a79
access-list outside_access_in line 1 extended permit tcp any host 10.10.10.31 eq smtp (hitcnt=0) 0x029b8a79
access-list outside_access_in line 2 extended permit tcp any object securewebmail eq https (hitcnt=0) 0xc7e21171
access-list outside_access_in line 2 extended permit tcp any host 10.10.10.31 eq https (hitcnt=0) 0xc7e21171
access-list outside_access_in line 3 extended permit tcp any object webmail eq www (hitcnt=0) 0xa3e2340f
access-list outside_access_in line 3 extended permit tcp any host 10.10.10.31 eq www (hitcnt=0) 0xa3e2340f
access-list outside_access_in line 4 extended permit tcp any object webserverpop3 eq pop3 (hitcnt=0) 0x5386a581
access-list outside_access_in line 4 extended permit tcp any host 10.10.10.31 eq pop3 (hitcnt=0) 0x5386a581
my packet tracer
lg-cus-fw-01(config)# packet-tracer input outside tcp fqdn google.com smtp 1$
Mapping FQDN google.com to IP address 74.125.225.72
(More IP addresses resolved. Please run "show dns-host" to check.)
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in 10.10.10.0 255.255.255.0 inside
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
does anyone know where is the rule? Is this something by defautl?
06-01-2012 11:03 AM
Hello Alex,
Can you provide us the following information:
Sh run object network ( Want to see the one for that host)
Sh run nat ( the one used by that host)
Sh run access-group
06-01-2012 11:16 AM
sh run object
object network mailserver
host 10.10.10.31
object network webmail
host 10.10.10.31
object network securewebmail
host 10.10.10.31
object network webserverpop3
host 10.10.10.31
nat (inside,outside) static interface service tcp smtp smtp
i have not configured access-group... could this be it?
Alex
06-01-2012 12:02 PM
Hello Alex.
Yes, that is
Access-group outside_access_in in interface outside
Julio
