Port forwarding on ASA 5505 ver 8.4(7)
Hi Folks,
I am trying to setup a port forwarding configuration of ASA in local network. Scenario is internet connected with DSL modem and ASA connected with DSL Modem. Modem redirecting all traffic to the single LAN IP (ASA).
Somehow I have tried to configured and its doesnot worked out so I configured agian basic connectivity with internet. I have two servers in inside network 1) 10.10.10.22 (S1) and 2) 10.10.10.100 (S2). I can abel to reach intenet from inside network but failed to configured port forwarding in ASA.
I would like to access servers from outside network using custom port forwarding. Need to forward ports 8080,443, 554, 8000 for 10.10.10.22 so whenever I request 192.168.1.100:8080 then its redirect to 10.10.10.22:80, 192.168.1.100:8443 to 10.10.10.22:443 or 554:8554 or 8000:8000, I also like to forward 192.168.1.100:80 to 10.10.10.100:80 & 192.168.1.100:443 to 10.10.10.100:443, however ASDM & SSH already enabled it is possible to foreard 443 port as 9443 for ASDM, if request 192.168.1.100:9443 then its point ASDM??
Can some one guide how to configure above requirement in current configuration on ASA 5505 8.4(7).
This is my 'show run':
Firewall(config)# sh running-config
: Saved
ASA Version 8.4(7)
hostname Firewall
domain-name xyz.com
enable password 8Ry2YjytI7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.1.100 255.255.255.0
ftp mode passive
dns server-group DefaultDNS
domain-name xyz.com
object network TEST
host 10.10.10.22
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
object network TEST
nat (inside,outside) static interface service tcp 8080 8080
nat (inside,outside) after-auto source dynamic any interface
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 10.10.10.10-10.10.10.100 inside
dhcpd dns 192.168.1.1 10.10.10.1 interface inside
dhcpd domain ramkabir.in interface inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
anyconnect-essentials
username harshil password zGuVcgsszE.QT3iL encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Many thanks
Everyone's tags (4)
Re: Port forwarding on ASA 5505 ver 8.4(7)
First create a network object-
object network 10.10.10.22-8080
host 10.10.10.22
Then add a NAT
You can only have one NAT per object so you'll have to create an object for each port translation
object network 10.10.10.22-554
host 10.10.10.22
nat (inside,outside) static interface service tcp 554 554
object network 10.10.10.22-443
host 10.10.10.22
nat (inside,outside) static interface service tcp 443 443
etc ...
Don't forget the ACL applied to the outside interface as well. Let us know if you need help with that.
1327
