Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Port forwarding problem
Hello all, looking for some assistance.
I am simply trying to grant RDP access from the outside Internet to an internal host -- 10.0.11.254 -- on the inside-2 network. The config below is edited, but I think I have all the relevant pieces in there.
Thanks for taking a look!
: Saved
: Written by enable_15 at 20:17:55.312 UTC Wed Jul 11 2012
ASA Version 8.2(1)
name 170.1.1.1 WAN-IP
interface Vlan1
nameif inside
security-level 100
ip address 10.0.3.2 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address WAN-IP 255.255.255.248
interface Vlan3
nameif inside-2
security-level 100
ip address 10.0.11.2 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
switchport protected
speed 100
duplex full
interface Ethernet0/1
speed 100
duplex full
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 3
speed 100
duplex full
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service rdp tcp
description for port 3389
port-object eq 3389
access-list outside_rdp_in extended permit tcp any interface outside eq 3389
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (inside-2) 1 0.0.0.0 0.0.0.0
static (inside-2,outside) tcp interface 3389 10.0.11.254 3389 netmask 255.255.255.255
static (inside,inside-2) 10.0.3.0 10.0.3.0 netmask 255.255.255.0
static (inside-2,inside) 10.0.11.0 10.0.11.0 netmask 255.255.255.0
access-group outside_rdp_in in interface outside
route outside 0.0.0.0 0.0.0.0 170.1.1.2 1
dynamic-access-policy-record DfltAccessPolicy
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
prompt hostname context
: end
Everyone's tags (2)
VIP Purple
Your NAT and ACL is in place. That looks good. Pleas post the output of the following command:
packet-tracer input outside tcp 1.2.3.4 1234 170.1.1.1 3389
Re: Port forwarding problem
Thank you, Karsten.
NOTE: The address 170.1.1.1 is not actual address. For the packet-trace, I replaced with actual outside address and the output follows.
ciscoasa# packet-tracer input outside tcp 1.2.3.4 1234 17x.x.x.x 3389
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
  match tcp inside-2 host 10.0.11.254 eq 3389 outside any
    static translation to WAN-IP/3389
    translate_hits = 0, untranslate_hits = 1
NAT divert to egress interface inside-2
Untranslate WAN-IP/3389 to 10.0.11.254/3389 using netmask 255.255.255.255
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (inside-2,inside) inside-2-network inside-2-network netmask 255.255.255.0
  match ip inside-2 inside-2-network 255.255.255.0 inside any
    static translation to inside-2-network
    translate_hits = 101, untranslate_hits = 249
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 1556762, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside-2
output-status: up
output-line-status: up
Action: allow
Super Bronze
Do you have somekind of LAN to LAN VPN configurations on the ASA or why is the packet-tracer giving a Phase for VPN also?
- Jouni
Yes, there are several LAN-to-LAN VPN tunnels. I cut those out of the posted config because I thought it wasn't relevant and it has a lot of public IPs + other revealing info.
I can edit and post it if you feel that it would be helpful.
I have some suspicion that the RDP request from outside is not even getting to the ASA. There is a "gateway" from our cable internet provider in front of the ASA, which might be doing some filtering. I will check that.
418
