Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Port forwarding with an ASA 5520
Hi all,
I've recently bought a Cisco ASA 5520 on eBay for study and I've decided to use it solely as a firewall between my home LAN and the Internet. Wow, what a learning curve! I've managed to add my internal networks as objects and create a NAT rule (thanks for youtube) to PAT my internal devices to get out to the Internet with ASDM but I'm really struggling to do the following: -
- allow any incoming traffic that hits the external facing interface destined for port 38921 and nat to 10.1.10.101:38921
- allow any incoming traffic that hits the external facing interface destined for port 30392 and nat to 10.1.10.101:30392
Can anyone guide me on how to do this, as I have a couple of services running behind these ports on a server that I want to get at when I'm not at home? My (rather messy) config is as follows: -
hostname FW1
enable password encrypted
passwd encrypted
names
interface GigabitEthernet0/0
description **External facing to Internet**
nameif Outside
security-level 0
ip address dhcp setroute
interface GigabitEthernet0/1
description **Internal Facing to 3750**
nameif Internal
security-level 100
ip address 10.1.10.2 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ftp mode passive
object network VLAN1
subnet 192.168.1.0 255.255.255.0
description Legacy
object network WiredLAN
subnet 10.1.10.0 255.255.255.0
description Wired LAN
object network CorporateWifi
subnet 10.1.160.0 255.255.255.0
description Corporate Wireless VLAN 160
object network GuestWifi
subnet 10.1.165.0 255.255.255.0
description Guest Wireless VLAN 165
object network LegacyLAN
description Legacy LAN in place until change over
object network FileServer
host 10.1.10.101
description File Server
object service Service1
service tcp source eq 38921 destination eq 38921
description 1st service
object-group network All_Inside_Networks
network-object object VLAN1
network-object object WiredLAN
network-object object CorporateWifi
network-object object GuestWifi
network-object object LegacyLAN
object-group service Service2 tcp-udp
port-object eq 30392
object-group service DM_INLINE_TCPUDP_1 tcp-udp
group-object Service2
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list Outside_access_in extended permit object-group TCPUDP any object FileServer object-group DM_INLINE_TCPUDP_1 inactive
access-list Outside_access_in extended permit object Service1 any object FileServer inactive
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu Internal 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-714.bin
no asdm history enable
arp timeout 14400
nat (Internal,Outside) source dynamic FileServer interface service Service1 Service1 inactive
nat (any,Outside) source dynamic All_Inside_Networks interface
access-group Outside_access_in in interface Outside
route Internal 10.1.160.0 255.255.255.0 10.1.10.1 1
route Internal 10.1.165.0 255.255.255.0 10.1.10.1 1
route Internal 192.168.1.0 255.255.255.0 10.1.10.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 10.1.160.15 255.255.255.255 Internal
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet 10.1.160.15 255.255.255.255 Internal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface Outside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username Barry password encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:19be38edefe8c3fd05e720aedee62c8e
: end
Everyone's tags (4)
3 ACCEPTED SOLUTIONS
Silver
1. This is just a configuration example and another option with to due this and avoid sending us the complete NAT configuration:
object network 10.1.10.101
host 10.1.10.101
object service 38921
object service 30392
service tcp source eq 30392
nat (inside,outside) 1 source static 10.1.10.101 interface service 38921  38921
nat (inside,outside) 1 source static 10.1.10.101 interface service 30392  30392
Let me know if it works
Value our effort and rate the assistance!
Silver
FYI: it is because of your manual NAT
Super Bronze
For some reason I managed to completely miss the Manual NAT configuration you had for Dynamic PAT.
As Jumora mentioned above the problem is the following command
Do do the following change
no nat (any,Outside) source dynamic All_Inside_Networks interface
nat (any,Outside) after-auto source dynamic All_Inside_Networks interface
Notice that this change will cause a small outage in the outbound connections as you are changing the Dynamic PAT configuration for all users. But this is the configuration that is causing problems with the Static PAT (Port Forward)
- Jouni
Super Bronze
So you want to configure Static PAT (Port Forward) for these 2 mentioned ports
You can accomplish that with the following configurations
object network STATIC-PAT-TCP38921
host 10.1.10.101
nat (Internal,outside) static interface service tcp 38921 38921
object network STATIC-PAT-TCP30392
host 10.1.10.101
nat (Internal,outside) static interface service tcp 30392 30392
access-list Outside_access_in extended permit tcp any object STATIC-PAT-TCP38921 eq 38921
access-list Outside_access_in extended permit tcp any object STATIC-PAT-TCP30392 eq 30392
A few things to consider
  • If either of the ports was actually meant to be UDP then replace the parameter "tcp" with "udp"
  • Choose your own names for the objects as they arent really descriptive of the actual service
You might also have the chance to configure Client VPN on your firewall which would enable you to access the servers securely without opening any other external access. You could either use IPsec VPN with a 3rd party VPN Client or Cisco AnyConnect if its installed on the ASA. But this is just a suggestion of what you could go for in the future.
I also wrote a document about the new NAT 8.3+ (software level) configuration format. Maybe it will help. It can be found here
https://supportforums.cisco.com/docs/DOC-31116
Hope this helps
Please do remember to mark a reply as the correct answer if it answered your question.
Feel free to ask more and naturally if you have some other NAT related or ASA configuration related problems then post a question here on the forums.
- Jouni
Thanks Jouni - I'll give that a try and post back with how it goes!
OK then... so... I've made the changes and tested this externally and it still doesn't work. I ran packet tracer to try and get an idea of what it's doing and this was the result: -
packet-tracer input Outside tcp 9.13.12.6 3456 10.1.10.101 30392
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   10.1.10.0       255.255.255.0   Internal
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Result:
input-interface: Outside
input-status: up
input-line-status: up
output-interface: Internal
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Then...
packet-tracer input Outside tcp 9.13.12.6 3456 [Public IP Address removed] 30392
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         Outside
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-status: up
output-interface: Outside
output-status: up
Action: drop
So when I'm trying to connect to the services on the public facing IP address from somewhere out on the Internet, it's being dropped by the implicit rule. Do I need a rule to allow any incoming on tcp port 30392? If so, once I add that rule am I simply going to start hitting the same NAT problem like in the first trace? How do I fix the NAT drop from the first trace?
Super Bronze
The first "packet-tracer" fails because you are using the internal IP address as the target. You will never see traffic coming from the Internet with the target IP address that is a private IP address. Because you target the internal IP address and not the public IP address then the other direction of the test matches no NAT rules and the reverse check fails because it matches a NAT rule. For the traffic to pass the traffic must match the same NAT rule on both direction. But the main problem here is that you are indeed targetting the internal IP address.
The problem with the second "packet-tracer" output is that its not matching any NAT configuration. Before any ACCESS-LIST Phase you should be seeing an UN-NAT Phase.
Since you are not seeing one the reason could be
  • You dont have the correct NAT configuration present
  • There is another NAT configuration present that overrides the Static PAT (Port Forward)
  • There is some bug that prevents the traffic from matching the correct NAT rule
To determine what the reason is we should see your NAT configuration.
Can you share the output of
show run nat
- Jouni
Silver
host 10.1.10.101
Silver
As I say, I've only just got this so it's all new to me. NAT config is as follows: -
FW# sh run nat
nat (Internal,Outside) static interface service tcp 38921 38921
nat (Internal,Outside) static interface service tcp 30392 30392
The first NAT rule (which I deactivated) was part of my original attempt to get this working...
Super Bronze
- Jouni
Thanks Jouni! As far as packet tracer is concerned, that seems to have done the trick. I'll test it externally when I next get the chance. Packet tracer now shows...
FW(config)# packet-tracer input Outside tcp 9.13.12.6 3456 [Public IP Address removed] 30392
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface Internal
Untranslate [Public IP Address removed]/30392 to 10.1.10.101/30392
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 2, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
So what is it that 'after-auto' keyword changes to allow the traffic flow?
And thanks too for you input Jumora! Much appreciated.
Super Bronze
Re: Port forwarding with an ASA 5520
Remember also to mark Jumoras reply as the correct answer since he noticed it first. He also provided another "nat" configuration that would work in your case.
I usually suggest changing the existing configuration though since it keeps the configuration clearer to read and manage in the long run but that is naturally my personal opinion only
With regards to the "after-auto" its there only to change the priority of the NAT configuration.
To give you the all the information shortly consider these facts about the new NAT behaviour and operation.
  • There are 2 NAT Rule types: Auto NAT and Manual NAT
    • Auto NAT is NAT configured under an "object"
    • Manual NAT is NOT configured under any "object" but rather uses "object" and "object-group" as its parameters
  • There are 3 Sections of NAT
    • Section 1 is Manual NAT
    • Section 2 is Auto NAT
    • Section 3 is Manual NAT
    • They are processed in that order for a match
  • Manual NAT is by default Section 1
    • The "nat" configuration WITHOUT "after-auto"
  • Auto NAT is always Section 2
    • For example the Static PAT (Port Forward) we configured
  • Manual NAT is also Section 3
    • The "nat" configuration WITH "after-auto"
So if you consider all the above mentioned points you will notice that we configured a Section 2 Auto NAT and you had a Section 1 Manual NAT. The Section 1 Manual NAT in this case overrided the Section 2 Auto NAT (since it uses the same public IP address) therefore the Static PAT we configured with Auto NAT didnt work. We then changed the existing configuration to include "after-auto". Since this means the NAT configuration is now Section 3 it means it cant override the Section 2 Auto NAT (Static PAT) we configured and it started working.
EDIT: The "after-auto" also refers that this NAT rule will be after Auto NAT which you will see if you look at the ASDM or CLI of the NAT configuration. You will notice the existing "nat" you changed has now moved to the very bottom.
Hope it makes sense
You can check a document I wrote for a bit more information about the above subject.
- Jouni
Thanks for the explanation - makes sense now. I'll take a look at the document too.
7814
