Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
port forwarding with asa 5510
I have a situtation where I have web servers with public IP addressess that I'm going to migrate behind one address, but behind different ports.
Can I do port forwarding with ASA so that when connecting from network 0.0.0.0 to port 80 on ip x.x.x.x would be redirected to ip y.y.y.y and for example to port 10054
1 REPLY
Silver
Re: port forwarding with asa 5510
static (inside,outside) tcp x.x.x.x 80 y.y.y.y 10054 netmask 255.255.255.255
with an
access-list outside_inside exteneded permit tcp any host x.x.x.x eq 80
This should help you. x.x.x.x is your public ip. y.y.y.y is private ip.
Hoogen
Do rate if this helps :)
266
