Port redirection for Asa in transparent mode
Can we make port redirection when we configuring Asa in transparent mode.
Regars
Aristide
Super Bronze
I have not personally had much dealings with the ASA in Transparent mode.
According to the ASA Configuration Guide it seems that NAT should be supported in Transparent mode.
Naturally the configuration format depends on the software level you are using on the ASA. What is your software level?
- Jouni
Thank you,
version 9.0 in Asa 5510
Aristide
Super Bronze
Well the basic format for Static PAT (Port Forward) would be
object network STATIC-PAT
host
nat (inside,outside) static service
Naturally "object" and interface names might be different.
Again, I have not used Transparent firewalls other than for testing and have not even tried configuring NAT with them so I dont know will this work.
The Configuration Guides Guidelines and Limitations section doesnt mention anything else for Auto NAT / Network Object NAT (the above configuration) than
  • Supported in Routed and Transparent mode
  • Have to define the source and destination interface in the "nat" command
  • Cant use "interface" PAT (since do IP configured on the actual interface in Transparent mode)
- Jouni
Thank you journi
Super Bronze
Let us know if it worked when you had the chance to test it out
- Jouni
Ok, I will back to you
Aristide
169
