Port Redirection (Forwading) from Inside to Outside
Dear All,
I have a requirement to configure a PIX.
It is a 515E with 6.3(5) software loaded.
We are connecting to a 3rd party via the Firewall.
It has 1 inside and 1 outside interface configured.
The requirement is that our internal hosts connect to a IP/Port combination on a Inside routable address and the PIX re-forwards the traffic to the outside host.
All documentation mentions configuring Outside (Internet) hosts so they can connect to a Outside IP/Port combination but not the reverse.
Why am I doing this?
Because the external 3rd party have a IP address range which were are not allowed to route internally.
Is this possible?
Any comments gratefully received!!
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Port Redirection (Forwading) from Inside to Outside
Oh for crying out loud :-)
Well done Craig, we were all so busy worrying about how to NAT a destination address that we completely overlooked the NAT on the source IP addresses !!
I should have spotted that and altho i don't want to speak for Sundar i think he will feel the same :)
Thanks for letting us know Craig
Jon
inside routable address: 192.168.5.1
Outside address: 172.16.5.1
static (outside,inside) 192.168.5.1 172.16.5.1 netmask 255.255.255.255
You can add in ports into your static statement if you want to.
Jon
Hi Jon,
Thanks for your reply.
Can I ask,
How would the config line above create the re-direction?
If I have the following
Inside host 192.168.5.10
PIX Inside routable address: 192.168.5.1
PIX Outside address: 172.16.5.1
External Host of 172.16.5.2
But cannot use the 172.16.5.0 network or 0.0.0.0 in my routing tables.
Using Port Redirection in PIX you can connect to a pseudo outside address that is configured on the outside interface of the PIX which then (unknowing to the initiating host) reconnects to a internal machine.
I need this, but in reverse.
We may be talking about different things here.
You need an address internally that routes to the pix inside interface. So lets say
inside interface of pix: 192.168.5.1
inside client: 192.168.5.10
You need an unused IP address from the 192.168.5.0/24 network eg 192.168.5.20
External host = 172.16.5.2
static (outside,inside) 192.168.5.20 172.16.5.2 netmask 255.255.255.255
You don't have to use 172.16.5.0 or 0.0.0.0 in your routing tables. Your 192.168.5.10 host just communicates with 192.168.5.20.
When the packet arrives at the pix internal interface the pix will translate the destination from 192.168.5.20 to 172.16.5.2 and then forward on to the external host.
If you don't have a spare address in your 192.168.5.0/24 network then you can use any address internally as long as it routes to the internal interface of the pix.
Does this make sense ?
Jon
Jon,
Thanks, with your assistance I am getting somewhere.
I have configured the line as above [substituting for my real addressing ;o) ], and am attempting a Telnet to the 192.168.5.20 address.
A show xlate does not display any translation occurring.
I have debug packet inside src 192.168.5.10
I can see packets being rec'd, as follows;
pixfirewall# --------- PACKET ---------
-- IP --
192.168.5.10 ==> 192.168.5.20
ver = 0x4 hlen = 0x5 tos = 0x0 tlen = 0x2c
id = 0x40b6 flags = 0x40 frag off=0x0
ttl = 0x78 proto=0x6 chksum = 0xdf9f
-- TCP --
source port = 0x1e81 dest port = 0x17syn
seq = 0xce871757
ack = 0x0
hlen = 0x6 window = 0xffff
checksum = 0xb19d urg = 0x0
tcp options:
0x2 0x4 0x5 0x50 -- DATA --
00000020: 00 00 41 |
..A
--------- END OF PACKET ---------
I have also run the command;
debug packet outside
But I can see no traffic exiting the outside of the PIX.
Is there any other debug commands I can use or tips?
Thanks again,
Craig.
Hi Craig
Can you check the following
1) You have a route to the remote network ( the real address )
2) You are allowing the traffic out if you have an access-list applied on the inside interface.
Jon
Hi Jon,
Re: 1)
I have a route outside configured (ping from the PIX is successful confirming IP connectivity OK)
Re 2)
I have a access-list that is current set to permit ip any any (on inside and outside interfaces ) [for initial testing purposes].
Plus packets are reaching the PIX and is confirmed by the previous debug).
I can see packets arriving on the internal interface as per my last post but the XLATE function is not pickup up the traffic.
I have attempted ;
show xlate
show xlate inside
show xlate outside
show xlate debug
--Which show nothing..
Are there any other suggestions ideas on this one?
Can you post a sanitised copy of config. I have used this command many times in our environment so i know it should work.
Jon
Craig,
Agree with Jon the static should work.
Let's say you have the following setup.
inside host: 192.168.1.10
outside host: 172.16.1.2
inside destination to get to the outside host: 192.168.1.20
static (outside,inside) 192.168.1.20 172.16.1.2 netmask 255.255.255.255
Any traffic initiated from inside to 192.168.1.20 the PIX will redirect it to the outside host address of 172.16.1.2. Does the outside host know how to route to your inside network?
Sundar
Hi Jon/Sundar,
Here you go...
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
interface ethernet3 auto shutdown
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 faillink security30
nameif ethernet3 intf3 security6
nameif ethernet4 intf4 security8
nameif ethernet5 intf5 security10
enable password xx encrypted
passwd xx encrypted
hostname pixfirewall
domain-name xx.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 150 permit ip any any
pager lines 24
logging timestamp
logging console debugging
logging buffered debugging
mtu outside 1500
mtu inside 1500
mtu faillink 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
ip address outside 172.16.5.2 255.255.255.0
ip address inside 192.168.5.1 255.255.255.0
no ip address faillink
no ip address intf3
no ip address intf4
no ip address intf5
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address faillink
no failover ip address intf3
no failover ip address intf4
no failover ip address intf5
pdm history enable
arp timeout 14400
static (outside,inside) 192.168.5.20 172.16.5.2 netmask 255.255.255.255 0 0
access-group 150 in interface outside
access-group 150 in interface inside
route outside 0.0.0.0 0.0.0.0 172.16.5.254 1
route inside 192.168.5.0 255.255.255.0 155.30.3.253 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
ntp server x.x.x.x source inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
pixfirewall#
Craig
172.16.5.2 is the address attached to your outside interface on the pix. You need to change this to be the host you are trying to get to eg if the actual address of the host you are trying to get to is 172.16.5.10
static (outside,inside) 192.168.5.20 172.16.5.10 netmask 255.255.255.255
Jon
DARN!!
That is how it is configured.
Its my mistake whilst I was sanitizing the config.
I guess we are out of ideas, the config is correct but I cannot seem to get traffic to work.
If I telnet to 192.168.5.20 I see Syn's from the originating machine sent to the PIX but no replies.
Also 'debug packet inside' shows the syn's arriving on the inside interface.
But, the traffic is not being NAT xlate'd..
Stuck...
:o(
-- IP --
id = 0xb57c flags = 0x40 frag off=0x0
ttl = 0x79 proto=0x6 chksum = 0x69da
-- TCP --
source port = 0x607d dest port = 0x17syn
seq = 0xbd3d6408
ack = 0x0
checksum = 0x343b urg = 0x0
tcp options:
..A
pixfirewall#
sho debug
debug access-list all
debug fixup tcp
debug packet outside both
debug packet inside src 192.168.5.10 both
pixfirewall#
Adding
debug icmp trace
Then pinging the Inside NAT ip
Show the following on the console;
ICMP echo-request from inside:192.168.5.10 to 192.168.5.20 ID=512 seq=4608 length=40
ICMP echo-request from inside:192.168.5.10 to 192.168.5.20 ID=512 seq=4864 length=40
ICMP echo-request from inside:192.168.5.10 to 192.168.5.20 ID=512 seq=5120 length=40
ICMP echo-request from inside:192.168.5.10 to 192.168.5.20 ID=512 seq=5376 length=40
But no XLATE is being created.
pixfirewall# sho xlate debug
0 in use, 0 most used
Flags: D - DNS, d - dump, I - identity, i - inside, n - no random,
o - outside, r - portmap, s - static
pixfirewall#
Craig
Okay, i think i know the problem. The NAT order of operation for the pix from inside interface to outside is to route first then NAT. I think the problem is that we have used an address out of the same subnet as the pix inside interface.
This would work fine on the outside interface because it NAT's first then routes.
I have used the config i supplied many times but what i never did now i come to think of it is to use an ip address out of the same subnet as the pix internal interface.
So would it be possible to do this
1) Use a private address that does not currently exist on your internal network and does not conflict with your remote partner.
eg 192.168.10.1
2) You now need to ensure that any traffic destined for 192.168.10.1 goes to the pix internal interface. Note that if the default gateway set on on your client 192.168.5.10 is the pix then you will be fine.
3) Change the static statement to
static (outside,inside) 192.168.10.1 172.16.5.10 netmask 255.255.255.255
Then make the connection from 192.168.5.10 to 192.168.10.1
I believe this will now work. Apologies for misleading you before, i forgot the NAT order of operation from inside to outside.
Please let me know how you get on
Jon
Jon,
It just works fine in my lab with the same setup that Craig has. It's a PIX515E running 7.2.2
Existing Configuration:
PIX515E(config)# show run static
PIX515E(config)# show xlate1 in use, 1 most used
Global 192.168.5.20 Local 172.16.5.10
PIX515E(config)# show access-list acl_outside
access-list acl_outside; 1 elements
access-list acl_outside line 1 extended permit icmp host 172.16.5.10 host 192.168.5.10 echo-reply (hitcnt=0) 0x9c61191a
PIX515E(config)# show run access-group
access-group acl_outside in interface outside
Pinged 192.168.5.20 from inside host 192.168.5.10 and echo replies.
access-list acl_outside line 1 extended permit icmp host 172.16.5.10 host 192.168.5.10 echo-reply (hitcnt=1) 0x9c61191a --> Return traffic matches.
Craig,
Can you verify the outside host (172.16.5.10) routes the traffic destined to 192.168.5.10 to the PIX outside interface (172.16.5.2).
Sundar
Hi Sundar
Didn't have access to a firewall to test so wasn't sure why it was not working for Craig.
Can you confirm that the inside IP address of the pix is in the 192.168.5.x range ? If so then it looks like it should work after all. As i say i have always used a separate subnet for this sort of thing from inside to outside.
Thanks for testing this out Sundar.
Jon
Not a problem Jon.
The inside host address is 192.168.5.10 and that's the same subnet as inside interface of the PIX itself. Actually, I configured two routers to be inside/outside host and enabled ICMP debugs on the outside router to make sure it wasn't the PIX that was sending proxy ARP replies to the inside host.
I am starting to wonder whether Craig may have to enable proxy ARP on the inside interface for this to work. I guess it wouldn't be a bad idea to try configuring 'no sysopt noproxyarp inside' and test.
Sundar
Sundar / Jon,
Once again, a big thank-you for your continued support - it is most appreciated.
I am running a 515e but with 6.3(5) software - so your lab is not using the same code.
Could there be a difference in NAT Order of Operation between 6.x and 7.x?
As this is in a remote site (in Africa) sadly there is no Infrastructure to create another VLAN & IP address range.
Is there a way to disable IP routing?
If the packets are arriving at the PIX and displayed by debug packet then I assume Proxy ARP is working correctly.?
Fixed!!
The following lines were required;
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
Jon
hai, your issue is of great useful to my project consideration
184
