Ports will not open in ASA 5505
We are trying to open ports 400 and 9799 on a 5505.I added these into the ACL and ran a port test but they still say closed. Do I have to add anything else other than a ACL statement?
Hello Mike
After adding into acl did you apply that acl on the interface?
If yes and still you see the issue then  send the output of packet tracer and also your config
regards
Gaurav
Post your config so we can assist.
Please rate replies and mark question as "answered" if applicable.
Heres what I have
access-list acl_out extended permit tcp any host 64.53.58.229 eq 9799
access-list acl_out extended permit udp any host 64.53.58.229 eq 9799
access-list acl_out extended permit udp any host 64.53.58.229 eq 400
access-list acl_out extended permit tcp any host 64.53.25.229 eq 9899
access-list acl_out extended permit udp any host 64.53.58.229 eq 9899
access-list acl_out extended permit tcp any host 64.53.58.229 eq 400
Hello Mike
The access list looking good.
But did you apply this command
if your public inerface name is outside
access-group acl_out in interface Outside
Also if it still did not work then probably it could be hitting a deny statement.
Can you send the output of this
packet tracer input outside tcp 4.2.2.2 2048  64.53.58.229 400 detailed
regards
Gaurav
Re: Ports will not open in ASA 5505
Gaurav,
I havent applied the command. I will try that. Thanks
106
