Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
PPPoE & ACLs
Cisco PIX Firewall Version 6.3
I recently enabled PPPoE and now my ACLs no longer permit incoming traffic to my public hosts (Outgoing traffic is fine).
I tried disabling 'ip audit', changing my static statements from 'interface' to the IP address, I even tried 'permit ip any any' and traffic still can't get through. The ACLs still show 'hitcnt=0' even though I'm hammering it from proxify.com and ShieldsUp.
I get nothing from 'debug packet outside', but when I run a capture it shows a lot of incoming requests in hex. When I import it into Ethereal, it shows a whole lot of incoming traffic, so it doesn't appear to be filtered by my ISP or my CPE.
For troubleshooting purposes, the Public address to my web server is <A HREF="javascript:newWin('http://74.2.65.94/')">http://74.2.65.94/</A>
My PPPoE config:
ip address outside pppoe setroute
vpdn group pppoex request dialout pppoe
vpdn group pppoex localname [MYPPPOEUSERNAME]
vpdn group pppoex ppp authentication pap
vpdn username [MYPPPOEUSERNAME] password *********
sh_run_080224.txt sanitized config
cap1.txt incoming hex dump
1 ACCEPTED SOLUTION
Community Member
Re: PPPoE & ACLs
HI,
The access lists are not bound to the outside interface .
Hence u need to add
access-list PUBLICHOSTS permit tcp any interface outside eq www
access-group PUBLICHOSTS in interface outside
Raj
Community Member
Re: PPPoE & ACLs
HI,
Hence u need to add
Raj
Community Member
Re: PPPoE & ACLs
rajbhatt- You ROCK!
How could I have forgotten to apply the ACL..?
I didn't need the other line;
I think because I already have;
access-list PUBLICHOSTS permit tcp any host eq www
THANKS!!
Community Member
Re: PPPoE & ACLs
Plz apply the key word interface outside in access list as from pppoe u may get a different ip address each time u connnect
Raj
Community Member
Re: PPPoE & ACLs
Do you mean 'access-list PUBLICHOSTS permit tcp any interface outside eq www '?
I added it per your suggestion.
This is good for PPPoE?
146
