Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
PPPoE & ICMP
Cisco PIX Firewall Version 6.3
My PIX was working just fine until I enabled PPPoE. Now that I've enabled PPPoE, I can no longer ping out. Now when I Ping out, I don't get responses back.
I tried disabling ip audit, permit icmp any any, I even tried permit ip any any, and that didn't work.
Here is my outbound ping request:
C:\>ping <A HREF="javascript:newWin('http://www.yahoo.com')">www.yahoo.com</A>
Pinging <A HREF="javascript:newWin('http://www.yahoo-ht3.akadns.net')">www.yahoo-ht3.akadns.net</A> [209.131.36.158] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 209.131.36.158:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
Here is the same request from the PIX:
# ping outside 209.131.36.158
209.131.36.158 response received -- 20ms
209.131.36.158 response received -- 10ms
And here is debug on the outside interface. It shows ping replys to the correct interface IP address.
# debug icmp trace
ICMP trace on
Warning: this may cause problems on busy networks
1: ICMP echo-request from inside:192.168.254.100 to 209.131.36.158 ID=512 seq=5478 4 length=40
2: ICMP echo-request: translating inside:192.168.254.100/512 to outside:74.2.65.94/5
3: ICMP echo-reply from outside:209.131.36.158 to 74.2.65.94 ID=5 seq=54784 length=40
4: ICMP echo-request from inside:192.168.254.100 to 209.131.36.158 ID=512 seq=55040 length=40
5: ICMP echo-request: translating inside:192.168.254.100/512 to outside:74.2.65.94/5
6: ICMP echo-reply from outside:209.131.36.158 to 74.2.65.94 ID=5 seq=55040 length=40
7: ICMP echo-request from inside:192.168.254.100 to 209.131.36.158 ID=512 seq=55296 length=40
8: ICMP echo-request: translating inside:192.168.254.100/512 to outside:74.2.65.94/5
9: ICMP echo-reply from outside:209.131.36.158 to 74.2.65.94 ID=5 seq=55296 length=40
10: ICMP echo-request from inside:192.168.254.100 to 209.131.36.158 ID=512 seq=55552 length=40
11: ICMP echo-request: translating inside:192.168.254.100/512 to outside:74.2.65.94/5
12: ICMP echo-reply from outside:209.131.36.158 to 74.2.65.94 ID=5 seq=55552 length=40
My ACLs:
access-list PUBLICHOSTS permit icmp any any echo-reply
icmp permit any echo-reply outside
My PPPoE config:
ip address outside pppoe setroute
vpdn group pppoex request dialout pppoe
vpdn group pppoex localname [MYPPPOEUSERNAME]
vpdn group pppoex ppp authentication pap
vpdn username [MYPPPOEUSERNAME] password *********
Is there something about PPPoE that could break ICMP replies?
My sanitized config is attached.
Thanks for your time!
1 REPLY
Community Member
Re: PPPoE & ICMP
It looks like I forgot to apply my ACL to the interface that permitted ICMP in.
After applying the ACL, I can ping out again.
DUH.
228
