PPPoe with Static IP
This is my first go with configuring PPPoe on a ASA 5505. We will be using a Static WAN IP Address. Does anyone see ANY issues with this configuration?
Please see attached for current config.
Thanks Mucho!!!!
1 ACCEPTED SOLUTION
Re: PPPoe with Static IP
Using PPPoE with a Fixed IP Address
You can also enable PPPoE by manually entering the IP address, using the ip address command from interface configuration mode in the following format:
hostname(config-if)# ip address ipaddress mask pppoe
This command causes the security appliance to use the specified address instead of negotiating with the PPPoE server to assign an address dynamically. Replace ipaddress and mask with the IP address and subnet mask assigned to your security appliance.
For example:
hostname(config-if)# ip address outside 201.n.n.n 255.255.255.0 pppoe
u config looks good
and check this note also important
The setroute option is an option of the ip address command that you can use to allow the access concentrator to set the default routes when the PPPoE client has not yet established a connection. When using the setroute option, you cannot have a statically defined route in the configuration
good luck
use the follwoing link as refrence
http://www.cisco.com/en/US/docs/security/asa/asa81/config/guide/pppoe.html
if helpful rate
Marwanshawi, yes, I was check it out earlier but was alittle confussed on where the Static Wan IP is placed. Please see the following:
interface Vlan2
description OUTSIDE_TO_ATT-DSL
nameif outside
security-level 0
pppoe client vpdn group att_dsl
ip address 70.xxxx.xxx.xxx 255.255.255.248 pppoe
Is this where it goes???
Thanks Mucho!!!!
For example:
u config looks good
good luck
654
