Prevent clients bypassing proxy
Hi all,
I was wondering if someone could help me out with a issue I have.  At present our corporation has all internet traffic routed via our HQ, through a Cisco ASA 5510 arrangement.  I need to prevent client machines (subnet / range) going directly out onto the internet, I need them to go via a proxy server.  My thought was to put a deny ACL on the outbound internal interface.  This would be something like deny ip [ip address] [subnet] interface outside with a permit rule for the proxy address.
Does anyone have any suggestions, or ideas as to how I could do this?
Any help would be much appreciated.
Thanks in advance.
Everyone's tags (2)
Re: Prevent clients bypassing proxy
Access list on the inside interface is the easiest and best way to do it. In
addition, you can also control it via NAT. Here is a sample config:
Access-list inside_access_out permit tcp host any eq 443
Access-list inside_access_out deny tcp any any eq 80
Access-list inside_access_out deny tcp any any eq 443
Access-list inside_access_out permit ip any any
Access-group inside_access_out in interface inside
Global (outside) 1 interface
Nat (inside) 1
Make sure that except for the servers that need direct internet access, no
other host has a NAT rule on the firewall. In that way, even if the hosts
try to bypass the access-list rule, they will not be able to go out without
the NAT rule.
Hope this helps.
NT
Hi NT,
Thanks for the quick reply.  I'll give it ago and let you know.
One afterthought though, would i need to specifically need to allow the internal IP's access to the DMZ??
Once again, thanks!
269
