Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Problem Accessing FWSM From Switch Console
I have a 6509 with FWSM in module 4. FWSM is configured in single context mode. After I configured passwords and authentication on the FWSM, I can no longer access the module using "session slot 4 processor 1" when connecting to the 6509 switch via console. Please note that if I ssh to 6509 then I can get to FWSM successfully.
Obviously I can remove authentication config to resolve the issue for now but I need to keep them in the final configuration and cannot figure out how they would cause the above issue to find a workaround ...
My Authentication config:
enable password xxx
passwd xxx
username admin nopassword privilege 15
aaa authentication ssh console TACACS+ LOCAL
aaa authentication http console TACACS+ LOCAL
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ (management) host x.x.x.x
timeout 5
key xxxxx
http server enable
http x.x.x.x 255.255.255.255 management
ssh x.x.x.x 255.255.255.255 management
telnet timeout 5
ssh timeout 5
console timeout 0
Thanks in advance for your help ...
Ali
149
