Problem configuration ASA 8.2 With HTTP access OUTDOOR
Hello
I have problem i want to access to my http server in my local network from outside
192.168.2.42 : it my server http
195.X.X.X  its my internet IP but it was connected in eth 0/4
static (DMZ,Orange) 195.X.X.X 192.168.2.42 netmask  255.255.255.255
access-list outside-acl permit tcp any host 195.X.X.X eq 80
access-group outside-acl in int orange
but its not good why
thanks for your help
VIP Purple
Re: Problem configuration ASA 8.2 With HTTP access OUTDOOR
"Orange" is your interface with the default-route to the internet?
You can use the packet-tracer to look at what the ASA would do with a packet:
packet-tracer input Orange tcp 1.2.3.4 1234 195.X.X.X 80
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Yes
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (DMZ,ORANGE) 195.X.X.X 192.168.2.42 netmask 255.255.255.255
nat-control
  match ip DMZ host 192.168.2.42 ORANGE any
    static translation to 195.X.X.X
    translate_hits = 26, untranslate_hits = 1
NAT divert to egress interface DMZ
Untranslate 195.X.X.X/0 to 192.168.2.42/0 using netmask 255.255.255.255
VIP Purple
that looks good, but half of the packet-tracer-output is missing ...
Sorry
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside-acl in interface ORANGE
access-list outside-acl extended permit tcp any host 195.x.x.x eq www
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
static (DMZ,ORANGE) 195.x.x.x 192.168.2.42 netmask 255.255.255.255
nat-control
    static translation to 195.x.x.x
    translate_hits = 0, untranslate_hits = 1
Phase: 7
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (DMZ,DMZ) tcp interface www 192.168.2.42 www netmask 255.255.255.255
nat-control
  match tcp DMZ host 192.168.2.42 eq 80 DMZ any
    static translation to 192.168.2.1/80
    translate_hits = 0, untranslate_hits = 0
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 2838450, packet dispatched to next module
Result:
input-interface: ORANGE
input-status: up
input-line-status: up
output-interface: DMZ
output-status: up
output-line-status: up
Action: allow
VIP Purple
Your ASA says it would allow the connection to the Server. So it's likely that the problem is somewhere else.
Local Firewall on the Server or other devices on the path that filter traffic?
No i have not other equipement for filter traffic and my server is a debian with just apache
VIP Purple
have you doublechecked the IP-config of the server? Default-gateway pointing to the ASA? Webserver running?
yes i can access to my webserver in local
VIP Purple
can the webserver reach the internet through the ASA?
Hello Piere,
Adding to what Karsten have tell you can you create some captures:
capture capin interface dmz match tcp any host 192.168.2.42. eq 80
capture caporange interface orange match tcp any host 195.xx.xx.xx eq 80.
capture asp type asp-drop all circular-buffer
Then try to connect from the outside world to the 195.xx.xx.xx on port 80. After you have done that please provide me the following information:
Show cap capout
Show cap capin
Show cap asp | inc  192.168.2.42
Rate all the helpful posts
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello thanks for your help
This capture don't worked
This capture worked
capture caporange interface orange match tcp any host 195.xx.xx.xx eq 80 :
1: 09:13:01.401773 802.1Q vlan#5 P0 195.6.x.x.48991 > 195.X.X.X.80: S 3140373812:3140373812(0) win 8192
   2: 09:13:04.405038 802.1Q vlan#5 P0 195.6.x.x.48991 > 195.X.X.X.80: S 3140373812:3140373812(0) win 8192
   3: 09:13:10.398477 802.1Q vlan#5 P0 195.6.x.x.48991 > 195.X.X.X.80: S 3140373812:3140373812(0) win 8192
   4: 09:13:22.397547 802.1Q vlan#5 P0 195.6.x.x.59070 > 195.X.X.X.80: S 3721082928:3721082928(0) win 8192
   5: 09:13:25.405496 802.1Q vlan#5 P0 195.6.x.x.59070 > 195.X.X.X.80: S 3721082928:3721082928(0) win 8192
   6: 09:13:31.398920 802.1Q vlan#5 P0 195.6.x.x.59070 > 195.X.X.X.80: S 3721082928:3721082928(0) win 8192
but i think i have problem between my  asa 5505 and my Modem
195.6.x.x > 195.X.X.X.80:
VIP Purple
the capture shows that the packets reach the ASA, but no traffic is coming back. If the problem would be the connection Modem-ASA, then the packets couldn't reach the ASA.
What didn't work with the capture "capin"? And can your server reach the internet through the ASA?
Yes if i Ping www.google.fr from my webserver is succeed ping from asa to my webserver is succeed
Hello Pierre,
Do the following
Show cap asp | inc  95.X.X.X and provide us the output you get.
Julio
Julio Carvajal
show capture asp | inc 195.6.100.5
1: 10:04:36.360516 802.1Q vlan#5 P0 90.149.249.151 > 195.6.100.5: icmp: host 90.149.249.151 unreachable - admin prohibited filter
   2: 10:04:37.985300 802.1Q vlan#5 P0 90.149.249.151 > 195.6.100.5: icmp: host 90.149.249.151 unreachable - admin prohibited filter
   6: 10:04:39.363277 802.1Q vlan#5 P0 90.149.249.151 > 195.6.100.5: icmp: host 90.149.249.151 unreachable - admin prohibited filter
   7: 10:04:39.651043 802.1Q vlan#5 P0 208.82.7.77.443 > 195.6.100.5.50051: . ack 660554390 win 8
   8: 10:04:39.654293 802.1Q vlan#5 P0 208.82.7.77.443 > 195.6.100.5.50051: . ack 660554427 win 7
  10: 10:04:40.992304 802.1Q vlan#5 P0 90.149.249.151 > 195.6.100.5: icmp: host 90.149.249.151 unreachable - admin prohibited filter
  14: 10:04:45.362377 802.1Q vlan#5 P0 90.149.249.151 > 195.6.100.5: icmp: host 90.149.249.151 unreachable - admin prohibited filter
  16: 10:04:46.999856 802.1Q vlan#5 P0 90.149.249.151 > 195.6.100.5: icmp: host 90.149.249.151 unreachable - admin prohibited filter
245: 10:10:34.160636 802.1Q vlan#5 P0 173.37.144.208.443 > 195.6.100.5.65501: . ack 4235667661 win 32768
271: 10:11:00.442954 802.1Q vlan#5 P0 69.171.242.74.80 > 195.6.100.5.57997: R 280852662:280852662(0) ack 3134889716 win 0 Drop-reason: (acl-drop) Flow is denied by configured rule
289: 10:11:06.073665 802.1Q vlan#5 P0 69.171.242.74.80 > 195.6.100.5.48029: R 4181768410:4181768410(0) ack 4072373161 win 0 Drop-reason: (acl-drop) Flow is denied by configured rule
560
