Problem in ASA 5510
ASA 5510
When I upgrade an  IOS ,  I made  mistake and deleted  flash(disk 0) .... after that I tried to put IOS via ROmmon mode from tftp server and get up IOS an  disk0: . "Everything" is OK ,
Once given the command "reboot" and everything is going off
Which means we cant able to login.
Some error message is follow.
Please help.
Manivel
1 REPLY
Problem in ASA 5510
Hello Mani,
Can you be a little more specific,
Are you saying your problem is that you copy the image from the TFTP to your ASA, then you rebot it and you get a log with an issue?
Is that correct?
Can we see the log mesage?
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
365
