Problem in ASA5520 with Asterisk Server , Softphone can't register
Static NAT
Real IP === Firewall === Asterisk Server
||======== Web Server
Now i create static nat from public ip to private ip both server,
I can't access to web server (i thing nat it work), But in softphone can't register to Asterisk Server
Config :
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit ip any any
static (inside,outside) 212.129.61.3 192.168.0.30 netmask 255.255.255.255
static (inside,outside) 212.129.61.4 192.168.0.31 netmask 255.255.255.255
static (inside,outside) 212.129.61.5 192.168.0.10 netmask 255.255.255.255
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect tftp
inspect sip
Please advice to me i must reconfig on ASA ?
Thank you so much
Re: Problem in ASA5520 with Asterisk Server , Softphone can't re
Try and disable inspect sip.
ASA (Asterisk Fix)
     no inspect sip
PIX (Asterisk Fix)
If you still have a PIX
do this
no fixup protocol sip 5060
no fixup protocol sip udp 5060
As everyone said remove the inspection and afterwards clear the local-host table for the hosts in discussion,
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Silver
The problem with asterisk is that in a normal setup without a Cisco firewall it would be obligated to define the global address or NATTED IP for SIP payload but with the ASA inspection the ASA needs to see the real IP so it can modify this payload with NATTED IP.
Just disable asterisk function to map the global IP and let the ASA inspect.
More information about SIP inspection on the next link:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081042c.shtml#sip
Value our effort and rate the assistance!
Silver
Did you understand what I was mentioning?
Silver
Help is for free then we need you to rate the assistance.
Silver
Are your issues resolved???
Jumora...i am not sure why you are upset...we are just contributing to the community...i had this issue a while back and i posted how i fixed it for others who might have the same issue.
Silver
The comment that is under what I am writing is just a comment that I post as part of a signature, it's a template, please don't take it personal, but I always comment that we need customer's to rate the assistance as we are taking time to answer their questions.
5322
