Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Problem in pix515 with ios7.2(3)
Actualy i can ping from inside to outside with ip 192.168.101.11, but can't ping from ip 192.168.101.123.I have also post the running config.Plz reply back asap.
thanks
Community Member
Re: Problem in pix515 with ios7.2(3)
This is because you have an Access-list set INBOUND on your inside interface and you do not have a permit statement to allow traffic to the address (192.168.101.123). You need to add the IP address or an Object group that it is listed in to the "inside_access_in" access-list.
Example
access-list inside_access_in extended permit ip object-group MailDNS object-group xxxxx
access-list inside_access_in extended permit ip host 192.168.101.123 object-group xxxxx
access-list inside_access_in extended permit ip object-group MailDNS1 ip host xxxxx
You will need to do this because the way your access-list reads you will block all IP traffic that is not implicitly allowed BEFORE you allow ICMP from any to any. So you will need to allow IP traffic from that address first or you will need to change the position of your two lines....
access-list inside_access_in extended deny ip any any
access-list inside_access_in extended permit icmp any any
to be....
Community Member
After modification (according to u), it is not working means still ip x.x.x.123 is not working, but other ip is working fine.Plz relpy asap.
Community Member
Did you add it to the object group and put the object group in your INBOUND IN access list? Or did you just add an entry for it alone?
118
