03-28-2009 02:53 PM - edited 03-11-2019 08:11 AM
I have a ftp-server running on 192.168.1.170 with port 21 and I want to do port forwarding in my Cisco ASA 5505.
The outside ip-address is 10.1.1.2 but I can't make a connection from a client with ip-address 10.1.1.1.
I did the same with a USRobotics router and it works as a charm. So the problem must be in the Cisco configuration.
My config:
: Saved
: Written by enable_15 at 12:57:10.202 UTC Sat Mar 28 2009
ASA Version 7.2(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 10.1.1.2 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
access-list outside_access_in extended permit tcp any interface outside eq ftp
access-list outside_access_in extended permit tcp any interface outside eq ftp-data
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface ftp 192.168.1.170 ftp netmask 255.255.255.255
static (inside,outside) tcp interface ftp-data 192.168.1.170 ftp netmask 255.255.255.255
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:08bbfacb3de9a0ecc718793d99d3effc
: end
kind regards,
ME
03-28-2009 07:10 PM
1) issue the below command
fixup protocol ftp 21 ( I read that this is necessary when you are natting the FTP-Server ip address, This will not show up in your running-config )
2) you don't need to permit ftp-data in your access-list applied to outside interface , as the firewall inspects ftp and dynamically opens the ports needed for the data channel.
so, the below ACE is not needed
and also the destination address in your ACE should be an ip-address (host 10.1.1.20) isn't it ??
3) the below static is wrong, you are forwarding ftp-data to ftp ,
static (inside,outside) tcp interface ftp-data 192.168.1.170 ftp( should be ftp-data )netmask 255.255.255.255
if it doesn't work with the above static, I suggest you do a one-one static instead of the existing 2 without port-forwarding
static (inside,outside) tcp interface 192.168.1.170 netmask 255.255.255.255
Vikram
03-28-2009 07:16 PM
You could try this
1.Create ACL
access-list outside_access_in permit tcp any host "ip address of outside interface' eg ftp
access-list outside_access_in permit tcp any host "ip address of outside interface' eg ftp-data
Apply to outside interface in the inbound direction
2. Add static statement
static (inside,outside) tcp interface ftp-data 192.168.1.170 ftp netmask 255.255.255.255 0 0
access-list outside_access_in extended permit tcp any interface outside eq ftp-data 0 0
03-28-2009 07:39 PM
try the following
1. remove "static" and "acl entry" related to ftp-data. since "inspect ftp" has been enabled, system will open port 20 automatically.
2. use IP address instead of "interface" in both ACL and static NAT config and try it again.
