Problem with Hairpinning on ASA
We have an ASA that needs to reroute an ASA to another firewall on the ASA's internal interface. The remote IPs are 10.12.14.0 / 24, so I've added the route to the ASA using "route inside 10.12.14.0 255.255.255.0 192.168.1.252", added "same-security-traffic permit intra-interface", and added the NAT statement "static (inside,inside) 192.168.1.0 192.168.1.0 netmask 255.255.255.0 norandomseq". Traffic is still not flowing but will if I put a static route into each of the local hosts. I've attached the packet tracer, but what confuses me is that phase 8 using "static (inside,inside)", phase 9 uses a static to our private cloud, and phase 11 uses yet another nat statement where the whole process fails. Can someone please help me figure out why traffic is going through so many nat processes and failing? The ASA is running 8.2(2).
ASA(config)# packet-tracer inp inside icmp 192.168.1.10 8 0 10.12.14.196
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.12.14.0      255.255.255.0   inside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group INSIDE-TEMP in interface inside
access-list INSIDE-TEMP extended permit ip any any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type:
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: DEBUG-ICMP
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype:
Result: ALLOW
Config:
  match ip inside 192.168.1.0 255.255.255.0 inside any
    static translation to 192.168.1.0
    translate_hits = 229, untranslate_hits = 710
Static translate 192.168.1.0/0 to 192.168.1.0/0 using netmask 255.255.255.0
Phase: 9
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (inside,outside) 192.168.99.0  access-list CBEYOND-NAT
  match ip inside 192.168.1.0 255.255.255.0 outside 10.216.14.64 255.255.255.224
    static translation to 192.168.99.0
    translate_hits = 1326, untranslate_hits = 414582
Phase: 10
Type:
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
nat (inside) 1 0.0.0.0 0.0.0.0
  match ip inside any inside any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 1639, untranslate_hits = 0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
1 ACCEPTED SOLUTION
Hi,As Harvey pointed out
As Harvey pointed out earlier , if you want to translate the addresses to the Interface inside IP , the above step should be good.
If you don't want to translate , you would have to add a NAT-EXEMPT on this inside interface to prevent it from using the :-
nat (inside) 1 0.0.0.0 0.0.0.0 >> As this is WIDE open for any IP
NAT exempt would be something like this:-
nat (inside) 0 access-list exempt
access-list exempt permit 192.168.1.0 255.255.255.0 10.12.14.0  255.255.255.0
access-list exempt permit 10.12.14.0  255.255.255.0 192.168.1.0 255.255.255.0
Or
Make the NAT statement much more specific
Thanks and Regards,
Vibhor Amrodia
Hi Baskervi, The packet
Hi Baskervi,
The packet tracer shows a drop due to RPF, it seems we are missing the global statement:
global (inside) 1 interface
Try adding that command and attach a new packet tracer.
Also try with real traffic.
Please remember to rate and select the correct answer.
Or
Thanks and Regards,
Vibhor Amrodia
Just another thought... I had
Just another thought... I had done this yesterday for just the top line and not the bottom line of your exempt access list entries. The server was able to ping the remote system for a couple minutes, then the timeouts started occurring. No hosts would able to access the remote locationl However, I put both lines in today, and it works, but I'm not sure why the second line would even matter as asymmetrical routing is occurring (into our firewall, into theirs, but the return traffic only comes from theirs directly to the host). I configured TCP state bypass, which I realize doesn't do anything for ICMP, but this is at least working for the moment. Thanks for your help.
This is a completely separate question, but the ASA doesn't appear to send ICMP redirections as the routers do. Is there a way to change this behavior?
I had actually tried "global
I had actually tried "global (inside) 1 interface" yesterday, but it still didn't work as shown in the following. However, I took it out because I created a static NAT rule, and it makes absolutely no sense to me why it would try the static NAT rule and then use the PAT rule. I've also tried with real traffic, which works with a static route on the server.
Phase: 11
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
    dynamic translation to pool 1 (192.168.1.1 [Interface PAT])
    translate_hits = 437, untranslate_hits = 0
Result:
input-status: up
output-status: up
Action: drop
191
