Problem with interface PAT in ASA 8.4
Hi.
I've an ASA5505 running 8.4 firmware
I'm trying to configure access to an internal FTP server using the same IP address we have in the outside interface.
The configuration is as follows:
object network FTP
host 192.168.125.32
object network FTP
nat (inside,outside) static interface service tcp ftp ftp
access-list outside_access_in line 3 extended permit tcp any object Fax eq ftp  log default
... But it doesn't work ...
If I use any other public accesible IP to do the NAT it works fine. For example:
     object network Fax
        nat (inside,outside) static 44.44.44.44 service tcp ftp ftp
So, is it not possible to use the outside interface of the ASA to redirect a port to an internal service??
It is not correct
it should be
access-list outside_access_in line 3 extended permit tcp any object FTP eq ftp  log default
Try with this
Rate this if it is helpful..
Re: Problem with interface PAT in ASA 8.4
Hi Gourav.
You are right. I made a mistake while copying the lines. But the problem persist with the changes you mention.
please provide your running config output .
Hi, I've the same issue with FTP on outside interface (other IP works well). Have you found any workaround? I'm running on 8.4.6
Hi.
I haven't found a solution. Finally I had to use other IP address than the one used by the outside interface.
703
