Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Problem with logging after upgrading to ASA 8.2
We have recently upgraded ASA to 8.2(1).
After upgrading we noticed that logging is not working, neither buffered nor traped.
Logging configuration is:
logging enable
logging timestamp
logging monitor warnings
logging buffered warnings
logging trap warnings
logging asdm warnings
logging queue 8192
logging device-id hostname
logging host INSIDE 1.1.1.1
logging class config trap warnings
An access-list example we use is:
access-lists test permit ip any any log warn
While hit counter increases, sh logg command is empty!!!!
Before upgrading (from 7.2(4)), logging was working correctly.
Any ideas?
1 REPLY
Community Member
Re: Problem with logging after upgrading to ASA 8.2
I found out that It's a well known bug (CSCsz73284). Even if you log warning level, it logs to informational.
To come around it, create a log list:
logging list log-list level warnings
logging list log-list message 106100
logging buffered log-list
logging trap log-list
211
