Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Problem with premium licence in Bundle ASA5540
Recently, I have bougth a bundle of ASA5540 with licence vpn premium and i checked two ASAs and i found this:
In the version 7.0
First ASA5540
show version
Cisco Adaptive Security Appliance Software Version 7.0(7)
Device Manager Version 5.0(7)
Compiled on Fri 06-Jul-07 10:37 by builders
System image file is "disk0:/asa707-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 35 secs
Hardware:   ASA5540, 1024 MB RAM, CPU Pentium 4 2000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   :  CNlite-MC-Boot-Cisco-1.2
                             SSL/IKE microcode:  CNlite-MC-IPSEC-Admin-3.03
                             IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.04
0: Ext: GigabitEthernet0/0  : address is 001d.a22c.6e58, irq 9
1: Ext: GigabitEthernet0/1  : address is 001d.a22c.6e59, irq 9
2: Ext: GigabitEthernet0/2  : address is 001d.a22c.6e5a, irq 9
3: Ext: GigabitEthernet0/3  : address is 001d.a22c.6e5b, irq 9
4: Ext: Management0/0       : address is 001d.a22c.6e5c, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs               : 200
Inside Hosts                : Unlimited
Failover                    : Active/Active
VPN-DES                     : Enabled
VPN-3DES-AES                : Enabled
Security Contexts           : 2
GTP/GPRS                    : Disabled
VPN Peers                   : 5000
This platform has an ASA 5540 VPN Premium license.
Serial Number: xxxxxxxx
Running Activation Key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Configuration register is 0x1
Configuration has not been modified since last system restart.
Second ASA5540
Cisco Adaptive Security Appliance Software Version 7.0(8)
Device Manager Version 5.0(8)
Compiled on Sat 31-May-08 23:48 by builders
System image file is "disk0:/asa708-k8.bin"
ciscoasa up 2 mins 24 secs
                             IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.05
0: Ext: GigabitEthernet0/0  : address is 001d.70df.312c, irq 9
1: Ext: GigabitEthernet0/1  : address is 001d.70df.312d, irq 9
2: Ext: GigabitEthernet0/2  : address is 001d.70df.312e, irq 9
3: Ext: GigabitEthernet0/3  : address is 001d.70df.312f, irq 9
4: Ext: Management0/0       : address is 001d.70df.3130, irq 11
Maximum VLANs               : 200
VPN-DES                     : Enabled
VPN-3DES-AES                : Disabled
GTP/GPRS                    : Disabled
VPN Peers                   : 5000
Serial Number: xxxxxxxxxxxxxxxx
Running Activation Key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
When i upgrade
In the version 8.0
First ASA5540
Cisco Adaptive Security Appliance Software Version 8.0(5)
Device Manager Version 6.2(5)53
Compiled on Mon 02-Nov-09 21:22 by builders
System image file is "disk0:/asa805-k8.bin"
ciscoasa up 1 min 46 secs
                             Boot microcode   :  CN1000-MC-BOOT-2.00
                             SSL/IKE microcode:  CNLite-MC-SSLm-PLUS-2.03
1: Ext: GigabitEthernet0/1  : address is 001d.a22c.6e59, irq 137
Maximum VLANs                : 200
VPN-DES                      : Enabled
GTP/GPRS                     : Disabled
VPN Peers                    : 5000
WebVPN Peers                 : 2
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions            : 2
Configuration last modified by enable_15 at 07:58:19.609 UTC Tue Apr 6 2010
Second ASA5540
ciscoasa up 58 secs
Maximum VLANs                : 200
VPN-DES                      : Enabled
GTP/GPRS                     : Disabled
VPN Peers                    : 5000
WebVPN Peers                 : 2
Serial Number: JMX1232L228
Running Activation Key: 0x25125461 0x20eec438 0x20a381e4 0xa1fc2c70 0x4f1aa8b1
This is a problem or the bundlen is OK? or I have to create the case in TAC? and i want to configure failover, will have any problem with this configuration?
Best Regards
Re: Problem with premium licence in Bundle ASA5540
License needs to be the same if you are going to run them in failover pair. You can get the 3DES license online, or alternatively you can contact the licensing team who can cut you the activation key for 3DES license.
Go to this link: https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?DemoKeys=Y
click on Cisco ASA 3DES/AES License
Fill in your info. and provide the serial number of this ASA that does not have VPN 3DES license.
-KS
608
