Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
problem with static nat
I am running an ASA 8.2 code.  I have a public ip address defined on one of my interfaces and all internal traffic is pat'd to that, it works well.  we asked for another public scope from the isp and we defined that on another interface of the firewall.  on this new  interface we have a device with an ip address within the new (public scope) but the problem it cannot be accessed from the internet, we know it's now an isp issue.
we can ping this device from the new interface but not from the old public ip interface.  i am pretty sure we are missing a static nat that allows traffic to communicate from the new to the old public segment defined on two different interfaces.
pls help
Hello Ronni Ronni,
They are both outside interface so I guess they have the same security level.
Do you have configured the same-security-level permit inter-interface
If you like you can post the running configuration and we can take a deeper look on this.
Julio Carvajal
Senior Network Security and Core Specialist
Community Member
Re: problem with static nat
yes I have same-security-level permit inter-interface.
Here is the config, I removed all the unncessary info such as vpn tunnels... if you see eth0/0 is our primary path to the internet and it has a public ip and eth0/3 is the 2nd one.  I have a bunch of allowed acl's to allow traffic to eth0/0 from the outside but removed those acl's from here, but i do have a permit ip any any to all outside traffic going the sip interface whitch is eth0/3
we have no issues with eth0/0 but when i connect a device to eth0/3 with an ip of the same segment it is not accessible from the internet.  note that there is no need to nat anything because the device has also a pulbic ip
interface Ethernet0/0
description primary internet
speed 100
duplex full
nameif outside
security-level 0
ip address
interface Ethernet0/1
description internal network
nameif inside
security-level 100
ip address
interface Ethernet0/2
description DMZ
nameif dmz
security-level 50
ip address
interface Ethernet0/3
description secondary internet
speed 100
duplex full
nameif sip
security-level 0
ip address
interface Management0/0
no nameif
no security-level
no ip address
boot system disk0:/asa824-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
tcp-map allow-probes
  tcp-options range 76 78 allow
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu sip 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
icmp permit any sip
asdm image disk0:/asdm-641.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1
access-group outside_in in interface outside
access-group inside_access_in in interface inside
access-group sip_traffic in interface sip
route outside
access-list sip_traffic extended permit ip any any
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
ssh timeout 60
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
class-map tcp-traffic
match access-list tcp-traffic
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect xdmcp
  inspect icmp
  inspect http
  inspect sip
class tcp-traffic
  set connection advanced-options allow-probes
service-policy global_policy global
i also added the following acl on the incoming to the outside access-group acl
permit ip any and i can see the hitct going up when i ping from the outside, but pings fail
i think i am missing a static nat, pretty sure.  also note that eth0/0 has a cable to the isp and eth0/3 is connected to some internal device with this pub ip segment, so everything has to go through eth0/0 for internet access, incoming and outgoing
Another point in my troubleshooting.  I run a packet capture and I see traffic hitting the eth0/0 int and eth0/3  but it's one way.
hi ,
Turn on syslog and see the error then adjust as necessary
Community Member
I see nothing in the logs, but the capture files show that the traffic is one way.
i am missing a nat i think but not sure
I have two simple question before I can answer ur question
1. Can you post your ACL ?
2. Where is your static which defines that the new devices on this new subnet is published to outside through the SIP interface.
Also your default route is pointing to "outside" so all traffic will go out that interface regardless where it is coming from , maybe your capture is saying one way for this reason.
Community Member
access-group acl_in in interface outside
access-group sip in interface sip
access-list sip extended permit ip any any
access-list acl_in extended permit ip any
int outside is my eth0/0 which is connected to the isp
int sip is my eth0/3 which is the new segment - to that interface i have a device with a pub ip defined in that vlan
when i ping both the firewall interface (sip) and the device of that interface i see the sip acl hitcnt going up
by the way the device off the sip interface can access teh interent, but problem it is not accessed from the outside
i don't have any stat nats, i tried this but it didn't work
static (sip,outside) netmask
in other words, all traffic hitting the outside int but destined to the sip interface, dont' nat it.  It did not work.
my default route is going to the outside as instructed by the isp
From your ACL what I understood is that you don't have any ACL applied to your outside interface , correct ?
Also from your explanation I can understand that your ISP has provided you with two set of subnets ip address and both having same gateway that is why you only have default route pointing to interface "outside" , this is strange for me I.e. two subnets having same gateway.
Good thing is that you can access the Internet from this devices . In our case we will try this first
You need the following on your FW to allow access to your device from outside,
Static (inside, outside)
Access-group out-in in interface outside
Community Member
i have the permit acl from the outside, but i am missing the static nat.
can you please send me the exact static nat i need to apply to allow traffic from the outside
to this new public segment on my eth0/3 interface.
I did write it in my post above , dunno any it got truncated , here goes again
Static (inside, outside) (public ip-address) (inside device ip-address ) netmask
iPad app has a bug
