Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem with VLANs and NAT
I am using ASA5510 with outside interface connected to Internet over PPPoE, inside for HQ LAN and one more interface connected to remote office. Traffic to remote office should be tagged with certain VLAN tag. Remote location should access HQ LAN and also access Internet thrugh this ASA.
The current configuration allows both LANs (HQ and remote office) to access Internet over outside, but the traffic between LANs is not possible. At the moment the global command is executed, there is no traffic between HQ LAN (192.168.5.0) and remote LAN (192.168.10.0).
When I ping the remote LAN from the ASA, ping is working. If I make a ping but from inside interface, ping is not working. If I ping from remote LAN to tehc subinterface addresse 192.168.12.1, ping is working. It seems like NAT disabled the traffic between remote LAN and HQ LAN.
Any advice? I need ping working between remote LAN and HQ LAN, as well as other ip traffic.
Here is the configuration:
show run
: Saved
ASA Version 8.0(3)
hostname fwvodabd1
enable password ********* encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
pppoe client vpdn group pppoegrp
ip address pppoe setroute
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.5.1 255.255.255.0
interface Ethernet0/2
no nameif
no security-level
no ip address
interface Ethernet0/2.1
vlan 3101
nameif tehc
security-level 100
ip address 192.168.12.1 255.255.255.252
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd ********* encrypted
ftp mode passive
same-security-traffic permit inter-interface
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu tehc 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.5.0 255.255.255.0
nat (tehc) 1 192.168.10.0 255.255.255.0
route tehc 192.168.10.0 255.255.255.0 192.168.12.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet 192.168.10.0 255.255.255.0 tehc
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group pppoegrp request dialout pppoe
vpdn group pppoegrp localname *********
vpdn group pppoegrp ppp authentication pap
vpdn username vodovodb1 password *********
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:d60f6017f39aa6a81a30902aa39ed0e6
: end
fwvodabd1(config)#
1 ACCEPTED SOLUTION
Re: Problem with VLANs and NAT
Traffic from lower security level to higher security level is denied by default. What is needed in this case is an inbound access list on the tehc interface allowing this.
access-list tehc-inbound line 1 extended permit ip 192.168.10.0 255.255.255.0 any
access-group tehc-inbound in interface tehc
please rate once your issue is solved ;)
Cheers
Questions:-
1) What device is 192.168.12.2 1?
2) Is your layer 2 device configured with the correct vlans?
Hi milan,
You definitely need 3 things in order for this to work:
1- On the ASA, you need to exclude traffic between the HQ and the Remote office from NATing (NAT exclude also called NAT zero):
access-list inside-NAT-Exclude line 1 permit ip 192.168.5.0 255.255.255.0 192.168.10.0 255.255.255.0
nat (inside) 0 access-list inside-NAT-Exclude
2- Allow icmp echo and echo reply on the ACLs relying between the inside and tech interface.
3- a static route on the layer 3 device (192.168.12.2):
ip route 192.168.5.0 255.255.255.0 192.168.12.1
Hope this helps.
Cheers and good luck
I tried what you suggested, but there is no traffic between inside and tehc interface.
The tehc interface is connected with one Sarian router, and remote LAN is at the other Sarian's router interface.
Without any nat and/or global command in ASA configuration, traffic (and ping) between local and remote LAN is going well, but none of the LAN can reach the Internet.
When I add nat/global commands, to allow Internet traffic, both LANs can reach internet over outside interface, but then there is no traffic inbetween local and remote LAN.
As I can debug traffic on remote Sarian router, I can see that I can ping 192.168.12.2 from ASA tehc interface, but cannot from ASA inside interface. At the moment when I ping from inside LAN, there is no traffic registered on remote Sarian router. It really seems that NAT excemption should help, but I tried with your suggestion and other similar possibilities, without any help. All the time, there is traffic to outside, but no intertraffic between inside LAN and LAN behind tehc interface.
Is there any debug method (seems that ASA does not support some NAT debugging technics that are present on Cisco routers)?
Can you decrease the security level (to 90 or less) for interface Ethernet0/2.1 and try NAT exclude?
When I decreased sec level of tehc interface to 90, I was able to reach remote LAN from local (inside) LAN. Access from remote LAN to local LAN is not allowed (probably due to decreased sec level on tehc interface). Of course, all that together with nat exclude commands you suggested.
Any advice how to allow traffic from remote LAN to local LAN, not loosing the internet traffic from both LANs?
And some more help with icmp access-lists, to allow pinging between LANs.
Thanks anyway.
Cheers
Milan,
The ASA should just have a static route for 192.168.10.0/24 to the router interface connected to the 192.168.12.0/25 network.
The router should have a default route pointing to the ASA for all traffic NOT in it's local routing table, 192.168.12.0/24 & 192.168.10.0/24 will be connected - the router is the device that will route between the 2 subnets.
ALL machines on the 192.168.12.0/24 should have a default gateway of the router. ALL machines on the 192.166.10.0/24 should have a default gateway of the router.
Then you just configure the nat statements in the PIX so the internal subnets 192.168.12.0/24 & 192.168.10.0/24 can browse the internet.
The router should be used as the primary layer 3 device to route traffic between 192.168.12.0/24 <> 192.168.10.0/24
HTH>
200
