Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
problem with VPN GRE and IOS Firewall
Hello. I have a problem with a Cisco 2800 Router. I can't connect from the inside network to outside using a GRE VPN client (MS). I did a packet capture and responses are coming on the outside interface but they never reach the inside interface. I allowed both IP protocol 47 and TCP 1723. I've attached the running config. Please help.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: problem with VPN GRE and IOS Firewall
i found this usefull:
http://siskiyoutech.com/blog/?p=78
hi ,
     you would require that you open up GREon the outside interface.
access-list ex 199 permit gre any any
that should take care of it.
Faisal Bhura
It doesn't work with the acl only, but the method described in the link above with the inspection policy did the trick. Thanks.
1184
