Problems with ASDM
Hi all,
Friends, i want to use web interface to config my pix 525... First, I installed java and then ASDM... when i click asdm luncher it write me that MSVCR71.dll was not found... after that i click buttom ok and the next window appears and there is writen that UNABLE to LOAD DLL CLIENT\JVM.dll
plz, helm me if you know what's the problem ...
P.D. the same thing i did on my notebook it there it works fine ...
Best regards
Giorgi Ninidze
Re: Problems with ASDM
Giorgi, try reinstalling asdm luncher software.
I already try it but not working... any idea ???
Giorgi Ninidze
Hmmm.. have you try accessing from another machine? If I read your original post you said it is ok from another machine? is this correct..
Jorge
I've already solve this problem.
Closed
Could you post what the problem was and how you reolved it.
Rgds
Jorge
Sure...
First i unistalled ASDM Luncher and Java (Don't forget ,,Program Files and Regedit'')... then restart PC... afther that install Java (Latest Version) Restar PC... then ASDM Luncher ... and it's all :))))
Giorgi Ninidze
992
