problems with VPN and NAT
I'm running a ASA 5505 with IOS 8.4
I was trying to setup anyconnect ssl vpn and now it's really strange, i cant get it to work.
I'm able to connect to the VPN service, but no network at all. I cant connect to either local hosts or to the internet when i'm connected to the VPN.
Below is my full config (masking password & public IP).
Anyone have any ideas? Or where i can start troubleshoot?
: Saved
ASA Version 8.4(4)1
hostname vpn
domain-name domain.com
enable password XXXXXXXXXXXXXXX encrypted
passwd XXXXXXXXXXXXX encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.240.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address X.Y.Z.Z 255.255.255.224
boot system disk0:/asa844-1-k8.bin
boot system disk0:/asa825-k8.bin
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 8.8.4.4
object network obj-192.168.240.0
subnet 192.168.240.0 255.255.255.0
object-group network NETWORK_OBJ_192.168.241.0_25
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list outside_access_in extended permit ip 192.168.240.0 255.255.255.0 any
access-list outside_access_in extended deny ip any any
access-list XXXXXX_VPN_ACL standard permit 192.168.240.0 255.255.255.0
access-list inside_access_in extended permit ip any any log disable
access-list inside_access_in extended deny ip any any
access-list nat-exempt extended permit ip 192.168.240.0 255.255.255.0 192.168.241.0 255.255.255.0
access-list VPN_ACL extended permit ip 192.168.240.0 255.255.255.0 any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPN_IP_POOL 192.168.241.50-192.168.241.70 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649-103.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 DGW_IP 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.240.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto map outside_map interface outside
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
subject-name CN=vpn.domain.com
keypair VPN
proxy-ldc-issuer
crl configure
crypto ca certificate chain ASDM_TrustPoint0
certificate 7e2d4352
    3082024c 308201b5 a0030201 0202047e 2d435230 0d06092a 864886f7 0d010105
    bed6f320 a5047dba 203db5cc b933cd52 25c7822d a525de87 9b521770 78e8ccff
    092a8648 86f70d01 01050500 03818100 0d5404b2 20db2566 ccf213d5 d00372a4
    e512093a da4f007d 5d7cb409 034dd59b 7df80f4f a9b7b014 4de91eaf beb8f3b4
    16a417ba 07c04292 881413fc 18c73894 2ccc3f2a 820c449a 70516774 cf859c3a
    f37b5397 4d4efc07 306a1ad2 04239f97 a26f8625 af4f90c5 28b47744 718656d8
    e885a641 e3517bff 8f64be2b 21fab9c5
  quit
telnet timeout 30
ssh timeout 30
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.240.101-192.168.240.132 inside
dhcpd dns dns1srv dns2srv interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_TrustPoint0 outside
webvpn
enable outside
anyconnect image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
anyconnect image disk0:/anyconnect-win-2.5.2014-k9.pkg 2
anyconnect enable
cache
  cache-static-content enable
group-policy DfltGrpPolicy attributes
dns-server value 8.8.8.8 8.8.4.4
vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-client ssl-clientless
split-tunnel-policy tunnelspecified
split-tunnel-network-list value XXXXXX_VPN_ACL
default-domain value domain.com
split-tunnel-all-dns enable
address-pools value VPN_IP_POOL
group-policy AnyConnect internal
group-policy AnyConnect attributes
wins-server none
vpn-tunnel-protocol ssl-client
username admin password XXXXXXXXXXX encrypted
tunnel-group DefaultWEBVPNGroup general-attributes
address-pool VPN_IP_POOL
default-group-policy AnyConnect
tunnel-group VPN type remote-access
tunnel-group VPN general-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:6b4b05d3f1dd7bd5888890f805018f32
: end
Everyone's tags (5)
Tried a packet trace and this is the output:
It fails in the NAT section and then the result is:
(acl-drop) flow is denied by configured rule
VIP Purple
Re: problems with VPN and NAT
Are you only testing with PING? If yes, then configure the folowing and also test with other services (http, ftp ...):
  inspect icmp
And for accessing the internet you have to configure either Split-Tunneling or NAT from outside to outside.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Right now im concerned about why i even cant access local network resources.
I've tried adding the above commands but it didnt helt out
I do receive these errors in the log:
Asymmetric NAT rules matched for forward and reverse flows; Connection for tcp src outside:192.168.241.51/49484(LOCAL\admin) dst inside:192.168.240.10/5000 denied due to NAT reverse path failure
Where 192..168.241.0 is my VPN IP pool and 192.168.240.0 is my local network.
VIP Purple
I just see it: You don't have any nat-exemption configured for your VPN-traffic:
object-group network VPN
  network-object 192.168.241.0 255.255.255.0
object-group network LAN
  network-object 192.168.240.0 255.255.255.0
nat  1 (any,outside) source static LAN LAN destination static VPN VPN no-proxy-arp route-lookup
Thanks, that solved the local network access.I still have problems with internet access now. I've checked my split tunneling but it still doesnt work, do you see anything wrong with split tunneling?
VIP Purple
Your combination of default- and configured groups is a little bit strange but still should work. I don't remember if the old AnyConnect-client 2.5 had some special behaviour. So I would change that to the newest 3.1 release. If that works you probably have to use a public certificate to get rid of the certificate-warnings.
What do you see under secured routes in the client after you establish the connection?
Im actually running version 3.1.01085
Under secured routes i see
192.168.240.0/24
390
