Prohibit traffic for particular users ASA5505
Hi Community.
I've read following guide how to use MPF and Regex.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940e04.shtml
What my question is how should the ASA know which user is now surfing in the web. Does the IE or Mozilla sends the usercredentials in the webstream ? How can the ASA extract from the HTTP traffic which user is now surfing.
Is MPF and Regex really working to prohibit traffic for particular users?
I dont think so, the only solution in my opinion is to use a proxy server.
Thanks guys and kind regards
1 ACCEPTED SOLUTION
Re: Prohibit traffic for particular users ASA5505
Hello Patrick,
No, you will be filtering or denying traffic based on the source IP address.
So that's how the ASA will filter the traffic, based on the source IP address and the respective MPF configuration.
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Bronze
is it vpn user?
No direct connected to the inside interface.
Hello Patrick,
Cheers,
Julio Carvajal
Hi Patrick,
I think you answered your question from the start.  ASA's can do deep HTTP inspection by inspecting MIME types and looking for REGEX strings.  However, like you pointed out, unless that string specifically has the user credentials or you can implement a REGEX to pull a consistent string your not going to be able to proxy your user traffic.
I have implemented HTTP Inspect Policy-Maps to restrict access to specific sites and I implemented the REGEX syntax to pull the URL strings.  I have only implemented on very rare occasions in the event the client didn't have a proxy and specific comprimise was communicating to a site or entity that had multiple Layer 3 destinations.
thanks.
95
