Public servers, protocol and port restriction on outside interface
Hi folks,
While setting up access to some internal servers that should be accessible from the outside, I noticed that I wasn't able to connect via port translated SSH, unless I allowed TCP and UDP on the outside interface, see rules below. The FakeSSH is SSH access, but with a custom port, that translates to standard SSH for the real server. The UDP is untranslated for a monitoring app.
I feel a bit queasy allowing ports that are not needed on the outside, though there are no corresponding NAT rules that can be usede for attacks. How can I restrict ports and protocols only to a bare minimum?
Best regards,
Peter
object network Server_Mail
host 192.168.0.212
object network Servicehelper
host 192.168.0.213
object network FakeSSH
host 192.168.0.213
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list outside_access_in extended permit object SMTP_Service any object Server_Mail
access-list outside_access_in extended permit object-group TCPUDP any object Servicehelper
nat (inside,outside) static interface service tcp smtp smtp
nat (inside,outside) static interface service udp 38885 38885
nat (inside,outside) static interface service tcp ssh 27210
nat (inside,outside) after-auto source dynamic any interface
access-group outside_access_in in interface outside
1 ACCEPTED SOLUTION
Super Bronze
Re: Public servers, protocol and port restriction on outside int
Did you first try allowing traffic to the port TCP/22?
Notice that with the 8.3+ introduced changes to NAT and ACL mean that you will be allowing traffic to the Real IP Address and Real Port.
This is because when the packet from the Internet arrives to the ASA "outside" interface the ASA will first UN-NAT the destination IP address and its port. So after that is done the actual ACL check will be done. And that means the destination IP/port has changed to 192.168.0.213 TCP/22
So your ACL for the SSH connection should be
access-list outside_access_in extended permit tcp any object FakeSSH eq 22
Let me know if that does it. Remove the TCP/UDP permitting rule before you try it out.
- Jouni
Super Bronze
- Jouni
Thanks again Jouni! Worked perfectly!
I'm from the Linux world, used to IP-tables and that stuff, so the workings of the Cisco ASA appliances is a bit awkward to me.
Wish you a nice weekend :-)
Peter
116
