Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Bronze
purpose of using sysopt connection tcpmss 0
Found this on an ASA I'm upgrading. Why set the tcp mss to 0?
Thanks.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Super Bronze
I can't really say why someone has changed the setting.
The default value is 1380
The value 0 seems to disable this feature completely. In other words if I have understood correctly, with the setting you mention, the ASA wont take part in deciding the maximum segment size when host behind 2 ASA interface initiate and negotiate a TCP connection.
Wonder if there is any special MTU settings on the ASA interfaces?
show run mtu
- Jouni
Super Bronze
show run mtu
- Jouni
Bronze
Thanks for your reply.
Checked the MTU's--good idea but they are all 1500.
This ASA has a lot of tunnels so my guess it was one of the tunnels, and whoever did this didn't know the procedure for Path MTU discovery
916
