Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Question about route (to and from) DMZ and Internal interface
Folks:
I need a little help here with a question that relates more to best practice then technical.
I currently have my lab configured
192.168.3.1 (internal)         192.168.1.0/24 (DMZ)
<>-------------------------------[Firewall]------------<>
+ Currently there is no route configured from 192.168.3.0 to 192.168.1.0.
- only directly connected
- c   192.168.3.0 255.255.255.0 is directrly connected, inside
+ Currently no route configured from 192.168.1.0 to 192.168.3.0
- only directly conetect
- c   192.168.1.0 255.255.255.0 is directrly connected, dmz
+ Internal servers use NAT address to the DMZ if needed
-Example: 192.168.3.5 ->NAT-> 192.168.1.5
+There is an ACL applied on the Internal interface
- access-list DMZ extended permit ip any any
+ From internal I can PING any device in the DMZ; however, from the DMZ I cannot ping any device on the 192.168.3.0/24 subnet, due to route not created.
My main question – is this safe since the DMZ does not have an route to the Internal network?
Thanks.
1 REPLY
Red
Can you share the configuration, that would determine if a I route is needed or not.
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
489
