Questions: ASA CSC-SSM and contexts
I just need to confirm if this two features are compatible. I haven't found any document denying it but haven't found anything with details on the configuration.
I believe each context will work independently with the CSC-SSM, but what about the content filtering license?
Any information will be greatly appreciated!
thanks!
1 ACCEPTED SOLUTION
Re: Questions: ASA CSC-SSM and contexts
Correct, each module needs its own license even if they are in failover.
PK
any ideas please??
Thanks!
No news?
I haven't tested it but I believe it should work.
The "csc" command is available in multiple context mode. The contexts will be redirecting traffic to the CSC.
The CSC does not know anything about contexts, it will just inspect traffic flows that it sees as it always does.
So it should work.
I hope it helps.
PK
Yes, thanks!
I believe so too.
I was wondering about  the licenses though.. I guess we need an active license on each module.
PK
279
