"no monitor-interface" from CSManager to ASA 5505 causes deployment failure
All,
I recently imported an ASA 5505 (code 8.2(1)) into Cisco Security Manager 3.3.0. When I try to deploy the config back, even if I make no changes, I get the following error(s) reported in the transcript:
Line# 2. (ERROR) Sent (Fri Oct 09 11:32:48 EDT 2009): no monitor-interface inside
Received (Fri Oct 09 11:32:48 EDT 2009): ERROR: Command requires failover license
Line# 3. (ERROR) Sent (Fri Oct 09 11:32:48 EDT 2009): no monitor-interface outside
I do understand why the command is failing; that's not the problem. The problem is that CSManager is sending this irrelevant and problematic command. I can't find a way to tell CSManager to not do this. (FlexConfig, for example, just lets you add more commands before or after the main config. You cannot tell it to *not* config something.)
I've been unable to find any mention of this on Cisco.com or in NetPro. Can anyone give me some advice?
Christopher Ursich
2 ACCEPTED SOLUTIONS
Re: "no monitor-interface" from CSManager to ASA 5505 causes dep
You are hitting a bug in csm 3.3, it's in the bug toolkit. I think there is a workaround, where you either enable monitor interfaces in the failover policy, to make csm not deploy those commands, as it thinks they are default enabled.
CSCta83590 CSM 3.3 'no monitor-interface' ASA base license deployment failure
The fix will *probably* be in SP1, but you should already be able to get a patch from TAC now.
Thanks to both respondents. Next time I will think to check the bug list too.
testing (please ignore)
712
