Radius auth to standby ASA in Active Active Failover
Hi Everyone,
When ASA is in Active/standby failover i can ssh to standby ASA using Radius.
But when ASA is in multi context mode  Active/Active failover i can not do Radius Auth to standby ASA?
Is this default behaviour?
MAhesh
  • Firewalling
VIP Green
I would not have thought this
I would not have thought this is the default behavior...but then again, I have never tested this.  If you console into the standby context issue the command show run | in aaa.  Which authentication database is indicated?
Please remember to select a correct answer and rate helpful posts
-- Please remember to rate and select a correct answer
 Hi Marius,both ASA active
Hi Marius,
both ASA active and standby in Active/active failover when i run the command
sh run | inc aaa
have same config with radius as protocol and same radius servers.
MAhesh
 Also when i run command sh
Also when i run command sh aaa-server on standby ASA it shows
Server status as Failed,Server disabled at
MAhesh
That is not the default
That is not the default behavior. Make sure you have all the IP's in your AAA server.
 Hi Collin,Both ASA have same
Hi Collin,
Both ASA have same IP's in their AAA server group.
MAhesh
Hall of Fame Super Silver
I think Collin was talking
I think Collin was talking about having the IP addresses for both the Active and Standby ASA (for each context) in your RADIUS server.
 Will check Entries of IP in
Will check Entries of IP in radius.
170
