RAVPN - Accessing remote l2l's - what's wrong?
Please find attached.
VPN (192.168.70.0/24) can connect to Internal LAN (192.168.10.0/23) but not the connected sites. These are working fine as can be pinged on the inside interface. When RAVPN tries it times out. Assuming remote end is correctly configured with same ACLS, what am I missing?
Very frustrating, a wealth of information online but alot of it is very hard to 'get'.
Simply I want remote the RAVPN clients to be able to get to remote sites, it works to the internal.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Super Bronze
Re: RAVPN - Accessing remote l2l's - what's wrong?
Just to double check one thing.
In the very first reply I mentioned you need to apply that one setting with the command
same-security-traffic permit intra-interface
Are you sure you added that command?
I mean you said you remembered already having that setting on. I'm just wondering if you missread the command I menioned in the my first post.
The setting you have on in the configuration attached is:
same-security-traffic permit inter-interface
Which basically allows traffic between 2 ASA interfaces that are of equal security-level. This setting in your case would make sense as you had both inside/outside at level 100.
Now the command that I posted was
Which basically means that traffic can come in and go out on the same interface. In this case it would be the outside interface.
If you could just double check this Think the command in CLI format is "show run same-security-traffic"
- Jouni
Super Bronze
I think you need the following command atleast
It allows the traffic leave the same interface its arrived
From Cisco material:
same-security-traffic intra-interface
command lets traffic enter and exit the same interface, which is  normally not allowed. This feature might be useful for VPN traffic that  enters an interface, but is then routed out the same interface. The VPN  traffic might be unencrypted in this case, or it might be reencrypted  for another VPN connection. For example, if you have a hub and spoke VPN  network, where the ASA is the hub, and remote VPN networks are spokes,  for one spoke to communicate with another spoke, traffic must go into  the ASA and then out again to the other spoke.
Also on that note, why is your outside interface also at security-level 100?
You also seems to have some extra networks in the first NAT rule
nat (Outside,Outside) source static DM_INLINE_NETWORK_1 DM_INLINE_NETWORK_1 destination static NETWORK_OBJ_192.168.70.0_24 NETWORK_OBJ_192.168.70.0_24 no-proxy-arp route-lookup
The DM_INLINE_NETWORK_1 includes your local LAN network which isnt located outside. Not sure if it really matters if its there but just something that I noticed when looking at the configurations.
- Jouni
Changed it back to 0, can't remember why it was changed.
I've added the command (although certain it was in that config already).
I've done as you've said with the nat command, still no joy.
Cheers,
Super Bronze
Hey,
I think I actually looked the NAT wrong originally.
Think you have the source and destination networks the wrong way. Alteast when looking from the point of view of the VPN Client. I guess it should still be bi-directional but im not sure. Would seem logical to have the VPN Client pool as the source though.
Maybe you could try to change the places of the DM_INLINE_NETWORK_1 and NETWORK_OBJ_192.168.70.0_24 in the NAT statement for (Outside,Outside)
- Jouni
Super Bronze
Also,
Monitoring the connections through ASDM at the  sametime would maybe give some clue whats happening to the connections  if they are not going through.
When the VPN Client tries to connect a remote L2L VPN network can you see any SA forming for the L2L VPN in question? Are any packets beeing encapsulated from the added VPN Client network 192.168.70.0 to the L2L VPN remote network of 192.168.60.0/24?
- Jouni
OK, have changed as per your suggestion and traced ASDM... ping says it is creating then tearing down, it shows no problems throughout.
Super Bronze
If you issue "show crypto ipsec sa peer 212.156.210.204" on the ASA can you copy/paste here the output where you see the statistics for the VPN-Pool network and the L2L VPN remote network.
- Jouni
show crypto ipsec sa peer 164.40.208.30
peer address: 164.40.208.30
    Crypto map tag: Outside_map, seq num: 1, local addr: 195.74.159.97
      access-list Outside_cryptomap extended permit ip 192.168.10.0 255.255.254.0 192.168.20.0 255.255.255.0
      local ident (addr/mask/prot/port): (192.168.10.0/255.255.254.0/0/0)
      remote ident (addr/mask/prot/port): (192.168.20.0/255.255.255.0/0/0)
      current_peer: 164.40.208.30
      #pkts encaps: 287091, #pkts encrypt: 287163, #pkts digest: 287163
      #pkts decaps: 388758, #pkts decrypt: 388758, #pkts verify: 388758
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 287091, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 72, #pre-frag failures: 0, #fragments created: 144
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 177
      #send errors: 0, #recv errors: 1345
      local crypto endpt.: 195.74.159.97/0, remote crypto endpt.: 164.40.208.30/0
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: FB2135F6
      current inbound spi : 0A88192A
    inbound esp sas:
      spi: 0x0A88192A (176691498)
         transform: esp-des esp-md5-hmac no compression
         in use settings ={L2L, Tunnel, }
         slot: 0, conn_id: 195604480, crypto-map: Outside_map
         sa timing: remaining key lifetime (sec): 1420
         IV size: 8 bytes
         replay detection support: Y
         Anti replay bitmap:
          0xFFFFFFFF 0xFFFFFFFF
    outbound esp sas:
      spi: 0xFB2135F6 (4213257718)
         sa timing: remaining key lifetime (sec): 1417
         IV size: 8 bytes
         Anti replay bitmap:
          0x00000000 0x00000001
I did it on another ip as i know this is fully configured, so i've been pinging 192.168.20.1.
Super Bronze
Hey,
That output doesnt include traffic from your VPN pool of  192.168.70.x.
It seems to be the output of your LANs traffic to the L2L VPN remote network
With the command you entered above, you should also see a section where the vpn pool network of 192.168.70.x is mentioned.
If you cant see that even after trying to the connections, either your connection attempt still arent handled correctly on the ASA or the remote end hasnt added configurations regarding your 192.168.70.0 network in the L2L VPN configurations
- Jouni
Hmm.
I'm starting to think this could be our hardware at the other end, it's not Cisco.
Unless you can think of any simple tests or checks, it works fine l2l but when adding the new subnet .70.0 to the remote firewall/routers it doesn't seem to want to play ball.
Super Bronze
Well,
Personally I would first check the configurations on both sides. In this case the encryption domains configured networks and the NAT translations for them. After that I would check through ASDM what happens to the connectiong through the logs. If that still wouldnt give me any results I would probably debug the actual L2L VPN connections and see if it gave any hint on the problem.
I'm not sure if the "packet-tracer" command would help in this situation.
- Jouni
Finally a bit more information!
Tunnel Manager has failed to establish an L2L SA.  All configured IKE versions failed to establish the tunnel. Map Tag= Outside_map.  Map Sequence Number = 1.
IKEv1 was unsuccessful at setting up a tunnel.  Map Tag = Outside_map.  Map Sequence Number = 1.
Group = 164.40.208.30, IP = 164.40.208.30, Removing peer from correlator table failed, no match!
Group = 164.40.208.30, IP = 164.40.208.30, QM FSM error (P2 struct &0xae49c120, mess id 0x42a8d8fc)!
So, I'm guessing... that this is because the encryption challenge on 192.168.70.0/24 RAVPN is different to 192.168.20.0/24 l2l (where the subnet has been placed). Would that make sense?
EDIT. Resetting up with same psk has stopped that error, still no comms though :S
Super Bronze
- Jouni
Here is the output:
I did read it . Now I have no crypto issues on the ASA but still not showing 192.168.70.0/24 when i run:
Super Bronze
Do you have an option to remotely create connections from the remote L2L VPN site towards the VPN Pool? Or have someone else do it or for example send continuous ICMP from the site?
If you can I guess this could provide the possibility to check if the L2L VPN section is OK. If you can generate that traffic and at the same time monitor if the VPN shows that traffic with the above mentioned command, you could atleast confirm that and we could concentrate on the VPN Client configurations and troubleshooting.
- Jouni
I've attached a log where i was pinging from both ends at the same time, if this helps please let me know - unable to do continuous though.
Draytek @ 192.168.20.0/24
ASA Internal @ 192.168.10/23
--> RAVPN @ 192.168.70.0/24
Super Bronze
Im not sure if I missed but I dont see any ICMP messages regarding the VPN Pool IP addresses of 192.168.70.0/24 ?
Can you ping both from the remote site using their local address to the VPN Client pool and vice versa and use ASDM to log the output or just copy it in the format you did the last.
- Jouni
192.168.70.2|21047|Teardown UDP connection 28491659 for Outside:84.252.252.154/33960 to Outside:192.168.70.2/21047 duration 0:02:41 bytes 489
192.168.70.2|63222|195.74.159.97|60843|Teardown dynamic TCP translation from any:192.168.70.2/63222 to Outside:195.74.159.97/60843 duration 0:02:30
192.168.70.2|63221|84.252.252.155|80|Teardown TCP connection 28490636 for Outside:192.168.70.2/63221 to Outside:84.252.252.155/80 duration 0:02:38 bytes 36175 Tunnel has been torn down
Any help?
Super Bronze
Hey,
Those messages seem to be about the connections that your VPN client takes to Internet through you ASA firewall.
They dont have a destination network 192.168.20.0/24 in them.
- Jouni
Apologies, please see below:
192.168.70.2 1 192.168.20.1 0 Teardown ICMP connection for faddr 192.168.70.2/1(LOCAL\SARemote) gaddr 192.168.20.1/0 laddr 192.168.20.1/0 (SARemote)
192.168.70.2 1 192.168.20.1 0 Built inbound ICMP connection for faddr 192.168.70.2/1(LOCAL\SARemote) gaddr 192.168.20.1/0 laddr 192.168.20.1/0 (SARemote)
192.168.70.2 59952   Failed to locate egress interface for UDP from Outside:192.168.70.2/59952 to 239.255.255.250/1900
192.168.70.2 54720 192.168.10.1 53 Teardown UDP connection 29298712 for Outside:192.168.70.2/54720(LOCAL\SARemote) to inside:192.168.10.1/53 duration 0:00:00 bytes 96 (SARemote)
Hi JouniForss,
I was facing the same problem and your suggestion below solved my problem and thank you very much.
- Jouni
So, a very slow update... (Draytek support):
Vigor routers doesn't support multiple IPSec SA(security association)
on single tunnel.A 'more' option only works between draytek routers to
route traffic to additional IP subnets.
I suggest you to enable another VPN profile to ASA public address but
use 192.168.70.0/24 as remote LAN subnet.
Draytek doesn't like it unless it's a Draytek device at the other end! I am giving Jouni correct answer as his troubleshooting would have fixed a cisco to cisco device.
1405
