RAVPN Connectivity issue through ASR
I have introduced a new ASR as well as an ISP in my network. Post actiivty we are unable to connect a few customer RAVPN. This connectiivty was working fine with old ISP with cisco 3945 router. For isolating the issue i have bypassed my firewall and tested a direct connection to my internet router however i am facing the same issue with RAVPN connectivity. We have checked the forward anf reverse trace route and confirmed the reachability.There is not access restriction from customer and this access is open over internet.
While connecting theis VPN with cisco vpn client software it will prompt for the credentials, after providing credentials the securityu negotiation is happening anf stopping at tjhis stage throwing an error " Not Connected" however the same credentials are working when i use a data card.
Packet Tracer
COGINBLRMBPB1INTF1# packet-tracer input INSIDE  udp 10.226.9.21 500 165.2.138.76 500 detailed
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         OUTSIDE
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.226.0.0      255.255.0.0     INSIDE
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside in interface INSIDE
access-list inside extended permit ip host 10.226.9.21 any
Forward Flow based lookup yields rule:
in  id=0x8e8134e0, priority=12, domain=permit, deny=false
        hits=111, user_data=0x9e7c5240, cs_id=0x0, flags=0x0, protocol=0
        src ip=10.226.9.21, mask=255.255.255.255, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0x9b8d9c20, priority=0, domain=inspect-ip-options, deny=true
        hits=15981449, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
Phase: 5
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
in  id=0x9b8dc8d8, priority=20, domain=lu, deny=false
        hits=14284592, user_data=0x0, cs_id=0x0, flags=0x0, protocol=17
Phase: 6
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (INSIDE,DMZ) 10.226.0.0 10.226.0.0 netmask 255.255.0.0
nat-control
  match ip INSIDE 10.226.0.0 255.255.0.0 DMZ any
    static translation to 10.226.0.0
    translate_hits = 0, untranslate_hits = 373903
in  id=0x53c5ca50, priority=5, domain=host, deny=false
        hits=24559939, user_data=0x53c5c408, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=10.226.0.0, mask=255.255.0.0, port=0
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (INSIDE) 99 10.226.9.21 255.255.255.255
nat-control
  match ip INSIDE host 10.226.9.21 OUTSIDE any
    dynamic translation to pool 99 (203.99.206.99)
    translate_hits = 1177, untranslate_hits = 17
Dynamic translate 10.226.9.21/500 to 203.99.206.99/32 using netmask 255.255.255.255
in  id=0x52ea22e0, priority=1, domain=nat, deny=false
        hits=1850, user_data=0x52ea2220, cs_id=0x0, flags=0x0, protocol=0
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Reverse Flow based lookup yields rule:
in  id=0x9b8bed80, priority=0, domain=inspect-ip-options, deny=true
        hits=36179513, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 73973987, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: INSIDE
input-status: up
input-line-status: up
output-interface: OUTSIDE
output-status: up
output-line-status: up
Action: allow
COGINBLRMBPB1INTF1(config)# sh capture capinside
21 packets captured
   1: 19:22:28.128716 10.226.174.64.55181 > 165.2.138.75.500:  udp 871
   2: 19:22:28.390772 165.2.138.75.500 > 10.226.174.64.55181:  udp 448
   3: 19:22:28.401285 10.226.174.64.55182 > 165.2.138.75.4500:  udp 160
   4: 19:22:28.401453 10.226.174.64.55182 > 165.2.138.75.4500:  udp 1
   5: 19:22:28.667552 165.2.138.75.4500 > 10.226.174.64.55182:  udp 88
   6: 19:22:28.668697 10.226.174.64.55182 > 165.2.138.75.4500:  udp 88
   7: 19:22:29.353802 10.226.174.64.55184 > 165.2.138.76.500:  udp 871
   8: 19:22:29.615263 165.2.138.76.500 > 10.226.174.64.55184:  udp 448
   9: 19:22:29.625684 10.226.174.64.55185 > 165.2.138.76.4500:  udp 160
  10: 19:22:29.625837 10.226.174.64.55185 > 165.2.138.76.4500:  udp 1
  11: 19:22:29.891769 165.2.138.76.4500 > 10.226.174.64.55185:  udp 72
  12: 19:22:39.976923 10.226.174.64.55185 > 165.2.138.76.4500:  udp 1
  13: 19:22:42.373088 10.226.174.64.55185 > 165.2.138.76.4500:  udp 96
  14: 19:22:45.835299 165.2.138.76.4500 > 10.226.174.64.55185:  udp 64
  15: 19:22:45.836336 10.226.174.64.55185 > 165.2.138.76.4500:  udp 64
  16: 19:22:45.851854 10.226.174.64.55185 > 165.2.138.76.4500:  udp 176
  17: 19:22:50.128426 10.226.174.64.55185 > 165.2.138.76.4500:  udp 1
  18: 19:22:51.142997 10.226.174.64.55185 > 165.2.138.76.4500:  udp 176
  19: 19:22:56.212131 10.226.174.64.55185 > 165.2.138.76.4500:  udp 176
  20: 19:23:00.269593 10.226.174.64.55185 > 165.2.138.76.4500:  udp 1
  21: 19:23:01.282562 10.226.174.64.55185 > 165.2.138.76.4500:  udp 176
21 packets shown
COGINBLRMBPB1INTF1(config)# sh capture capoutside
23 packets captured
   1: 19:22:28.128731 10.226.174.64.55181 > 165.2.138.75.500:  udp 871
   2: 19:22:28.390787 165.2.138.75.500 > 10.226.174.64.55181:  udp 448
   4: 19:22:28.401468 10.226.174.64.55182 > 165.2.138.75.4500:  udp 1
  12: 19:22:39.976939 10.226.174.64.55185 > 165.2.138.76.4500:  udp 1
  22: 19:23:06.353100 10.226.174.64.55185 > 165.2.138.76.4500:  udp 88
  23: 19:23:06.353695 10.226.174.64.55185 > 165.2.138.76.4500:  udp 88
23 packets shown
Logs
isco Systems VPN Client Version 5.0.00.0340
Copyright (C) 1998-2006 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.1.7601 Service Pack 1
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1      21:51:08.093  08/21/13  Sev=Info/6  CERT/0x63600025
Attempting to find a Certificate using Serial Hash.
2      21:51:08.093  08/21/13  Sev=Info/6  CERT/0x63600026
Found a Certificate using Serial Hash.
3      21:51:08.103  08/21/13  Sev=Info/6  GUI/0x63B00011
Reloaded the Certificates in all Certificate Stores successfully.
4      21:51:13.797  08/21/13  Sev=Info/4  CM/0x63100002
Begin connection process
5      21:51:13.997  08/21/13  Sev=Info/4  CM/0x63100004
Establish secure connection
6      21:51:13.997  08/21/13  Sev=Info/4  CM/0x63100024
Attempt connection with server "ihgvpn.ihg.com"
7      21:51:14.149  08/21/13  Sev=Info/6  IKE/0x6300003B
Attempting to establish a connection with 165.2.138.75.
8      21:51:14.558  08/21/13  Sev=Info/4  IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 165.2.138.75
9      21:51:14.558  08/21/13  Sev=Info/4  IPSEC/0x63700008
IPSec driver successfully started
10     21:51:14.558  08/21/13  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
11     21:51:14.558  08/21/13  Sev=Info/4 IPSEC/0x6370000D
Key(s) deleted by Interface (10.226.174.64)
12     21:51:14.808  08/21/13  Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 165.2.138.75
13     21:51:14.808  08/21/13  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Nat-T), NAT-D, NAT-D, VID(Frag), VID(?), VID(?)) from 165.2.138.75
14     21:51:14.808  08/21/13  Sev=Info/5 IKE/0x63000001
Peer is a Cisco-Unity compliant peer
15     21:51:14.808  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
16     21:51:14.808  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports DPD
17     21:51:14.818  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports NAT-T
18     21:51:14.818  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports IKE fragmentation payloads
19     21:51:14.818  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports DWR Code and DWR Text
20     21:51:14.818  08/21/13  Sev=Info/6 IKE/0x63000001
IOS Vendor ID Contruction successful
21     21:51:14.818  08/21/13  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to 165.2.138.75
22     21:51:14.818  08/21/13  Sev=Info/6 IKE/0x63000055
Sent a keepalive on the IPSec SA
23     21:51:14.818  08/21/13  Sev=Info/4 IKE/0x63000083
IKE Port in use - Local Port =  0xE2FF, Remote Port = 0x1194
24     21:51:14.818  08/21/13  Sev=Info/5 IKE/0x63000072
Automatic NAT Detection Status:
   Remote end is NOT behind a NAT device
   This   end IS behind a NAT device
25     21:51:14.888  08/21/13  Sev=Info/4 CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
26     21:51:15.058  08/21/13  Sev=Info/5 IKE/0x6300002F
27     21:51:15.058  08/21/13  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:LOAD_BALANCE) from 165.2.138.75
28     21:51:15.058  08/21/13  Sev=Info/4 CM/0x6310001B
Received alternative server address "165.2.138.77" from primary server
29     21:51:15.068  08/21/13  Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=9C5ABF33619C3DC0 R_Cookie=E6748AAC49256A96) reason = DEL_REASON_LOAD_BALANCING
30     21:51:15.068  08/21/13  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DWR) to 165.2.138.75
31     21:51:16.066  08/21/13  Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=9C5ABF33619C3DC0 R_Cookie=E6748AAC49256A96) reason = DEL_REASON_LOAD_BALANCING
32     21:51:16.066  08/21/13  Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "ihgvpn.ihg.com" because of "DEL_REASON_LOAD_BALANCING"
33     21:51:16.066  08/21/13  Sev=Info/4 CM/0x63100010
Try alternative server "165.2.138.77" given by the primary server
34     21:51:16.066  08/21/13  Sev=Info/4 CM/0x63100024
Attempt connection with server "165.2.138.77"
35     21:51:16.066  08/21/13  Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 165.2.138.77.
36     21:51:16.316  08/21/13  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 165.2.138.77
37     21:51:16.566  08/21/13  Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 165.2.138.77
38     21:51:16.566  08/21/13  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Nat-T), NAT-D, NAT-D, VID(Frag), VID(?), VID(?)) from 165.2.138.77
39     21:51:16.566  08/21/13  Sev=Info/5 IKE/0x63000001
40     21:51:16.566  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
41     21:51:16.566  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports DPD
42     21:51:16.566  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports NAT-T
43     21:51:16.566  08/21/13  Sev=Info/5 IKE/0x63000001
44     21:51:16.566  08/21/13  Sev=Info/5 IKE/0x63000001
45     21:51:16.576  08/21/13  Sev=Info/6 IKE/0x63000001
46     21:51:16.576  08/21/13  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to 165.2.138.77
47     21:51:16.576  08/21/13  Sev=Info/6 IKE/0x63000055
48     21:51:16.576  08/21/13  Sev=Info/4 IKE/0x63000083
IKE Port in use - Local Port =  0xE302, Remote Port = 0x1194
49     21:51:16.576  08/21/13  Sev=Info/5 IKE/0x63000072
50     21:51:16.576  08/21/13  Sev=Info/4 CM/0x6310000E
51     21:51:16.815  08/21/13  Sev=Info/5 IKE/0x6300002F
52     21:51:16.815  08/21/13  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 165.2.138.77
53     21:51:16.815  08/21/13  Sev=Info/4 CM/0x63100015
Launch xAuth application
54     21:51:26.715  08/21/13  Sev=Info/6 IKE/0x63000055
55     21:51:31.798  08/21/13  Sev=Info/4 CM/0x63100017
xAuth application returned
56     21:51:31.798  08/21/13  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 165.2.138.77
57     21:51:34.055  08/21/13  Sev=Info/5 IKE/0x6300002F
58     21:51:34.055  08/21/13  Sev=Info/4 IKE/0x63000014
59     21:51:34.055  08/21/13  Sev=Info/4 IKE/0x63000013
60     21:51:34.055  08/21/13  Sev=Info/4 CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
61     21:51:34.085  08/21/13  Sev=Info/5 IKE/0x6300005E
Client sending a firewall request to concentrator
62     21:51:34.085  08/21/13  Sev=Info/4 IKE/0x63000013
63     21:51:36.914  08/21/13  Sev=Info/6 IKE/0x63000055
64     21:51:39.450  08/21/13  Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
65     21:51:39.450  08/21/13  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(Retransmission) to 165.2.138.77
66     21:51:44.519  08/21/13  Sev=Info/4 IKE/0x63000021
67     21:51:44.519  08/21/13  Sev=Info/4 IKE/0x63000013
68     21:51:47.044  08/21/13  Sev=Info/6 IKE/0x63000055
69     21:51:49.731  08/21/13  Sev=Info/4 IKE/0x63000021
70     21:51:49.731  08/21/13  Sev=Info/4 IKE/0x63000013
71     21:51:54.827  08/21/13  Sev=Info/4 IKE/0x6300002D
Phase-2 retransmission count exceeded: MsgID=B65556F6
72     21:51:54.827  08/21/13  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) to 165.2.138.77
73     21:51:54.827  08/21/13  Sev=Info/6 IKE/0x6300003D
Sending DPD request to 165.2.138.77, our seq# = 625294116
74     21:51:54.827  08/21/13  Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=D82A4B8D0AE3DB4C R_Cookie=E71B85E64DC3760E) reason = DEL_REASON_IKE_NEG_FAILED
75     21:51:54.827  08/21/13  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DWR) to 165.2.138.77
76     21:51:57.883  08/21/13  Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=D82A4B8D0AE3DB4C R_Cookie=E71B85E64DC3760E) reason = DEL_REASON_IKE_NEG_FAILED
77     21:51:57.883  08/21/13  Sev=Info/4 CM/0x6310000F
Phase 1 SA deleted before Mode Config is completed cause by "DEL_REASON_IKE_NEG_FAILED".  0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
78     21:51:57.883  08/21/13  Sev=Info/4 CM/0x6310000C
All connection attempts with backup server failed
79     21:51:57.883  08/21/13  Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
80     21:51:57.883  08/21/13  Sev=Info/6 CM/0x63100046
Set tunnel established flag in registry to 0.
81     21:51:57.883  08/21/13  Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
82     21:51:57.883  08/21/13  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
83     21:51:57.883  08/21/13  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
84     21:51:57.883  08/21/13  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
85     21:51:57.883  08/21/13  Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
86     22:01:13.769  08/21/13  Sev=Info/4 CM/0x63100002
87     22:01:13.829  08/21/13  Sev=Info/4 CM/0x63100004
88     22:01:13.829  08/21/13  Sev=Info/4 CM/0x63100024
Attempt connection with server "165.2.138.76"
89     22:01:13.849  08/21/13  Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 165.2.138.76.
90     22:01:13.869  08/21/13  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 165.2.138.76
91     22:01:14.129  08/21/13  Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 165.2.138.76
92     22:01:14.129  08/21/13  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Nat-T), NAT-D, NAT-D, VID(Frag), VID(?), VID(?)) from 165.2.138.76
93     22:01:14.129  08/21/13  Sev=Info/5 IKE/0x63000001
94     22:01:14.129  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
95     22:01:14.129  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports DPD
96     22:01:14.129  08/21/13  Sev=Info/5 IKE/0x63000001
Peer supports NAT-T
97     22:01:14.129  08/21/13  Sev=Info/5 IKE/0x63000001
98     22:01:14.129  08/21/13  Sev=Info/5 IKE/0x63000001
99     22:01:14.139  08/21/13  Sev=Info/6 IKE/0x63000001
100    22:01:14.139  08/21/13  Sev=Info/4               IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to 165.2.138.76
101    22:01:14.139  08/21/13  Sev=Info/6               IKE/0x63000055
102    22:01:14.139  08/21/13  Sev=Info/4               IKE/0x63000083
IKE Port in use - Local Port =  0xC1DB, Remote Port = 0x1194
103    22:01:14.139  08/21/13  Sev=Info/5               IKE/0x63000072
104    22:01:14.139  08/21/13  Sev=Info/4               CM/0x6310000E
105    22:01:14.249  08/21/13  Sev=Info/4               IPSEC/0x63700008
106    22:01:14.249  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
107    22:01:14.389  08/21/13  Sev=Info/5               IKE/0x6300002F
108    22:01:14.389  08/21/13  Sev=Info/4               IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 165.2.138.76
109    22:01:14.389  08/21/13  Sev=Info/4               CM/0x63100015
110    22:01:24.488  08/21/13  Sev=Info/6               IKE/0x63000055
111    22:01:34.666  08/21/13  Sev=Info/6               IKE/0x63000055
112    22:01:41.145  08/21/13  Sev=Info/4               CM/0x63100017
113    22:01:41.145  08/21/13  Sev=Info/4               IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 165.2.138.76
114    22:01:43.425  08/21/13  Sev=Info/5               IKE/0x6300002F
115    22:01:43.425  08/21/13  Sev=Info/4               IKE/0x63000014
116    22:01:43.425  08/21/13  Sev=Info/4               IKE/0x63000013
117    22:01:43.425  08/21/13  Sev=Info/4               CM/0x6310000E
118    22:01:43.445  08/21/13  Sev=Info/5               IKE/0x6300005E
119    22:01:43.445  08/21/13  Sev=Info/4               IKE/0x63000013
120    22:01:44.805  08/21/13  Sev=Info/6               IKE/0x63000055
121    22:01:48.874  08/21/13  Sev=Info/4               IKE/0x63000021
122    22:01:48.874  08/21/13  Sev=Info/4               IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(Retransmission) to 165.2.138.76
123    22:01:53.933  08/21/13  Sev=Info/4               IKE/0x63000021
124    22:01:53.933  08/21/13  Sev=Info/4               IKE/0x63000013
125    22:01:54.953  08/21/13  Sev=Info/6               IKE/0x63000055
126    22:01:59.052  08/21/13  Sev=Info/4               IKE/0x63000021
127    22:01:59.052  08/21/13  Sev=Info/4               IKE/0x63000013
128    22:02:04.122  08/21/13  Sev=Info/4               IKE/0x6300002D
Phase-2 retransmission count exceeded: MsgID=AD3A35C4
129    22:02:04.122  08/21/13  Sev=Info/4               IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) to 165.2.138.76
130    22:02:04.122  08/21/13  Sev=Info/6               IKE/0x6300003D
Sending DPD request to 165.2.138.76, our seq# = 1747237174
131    22:02:04.122  08/21/13  Sev=Info/4               IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=2A1D2C03664EE3AC R_Cookie=ED9D78145C87F192) reason = DEL_REASON_IKE_NEG_FAILED
132    22:02:04.122  08/21/13  Sev=Info/4               IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DWR) to 165.2.138.76
133    22:02:07.161  08/21/13  Sev=Info/4               IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=2A1D2C03664EE3AC R_Cookie=ED9D78145C87F192) reason = DEL_REASON_IKE_NEG_FAILED
134    22:02:07.161  08/21/13  Sev=Info/4               CM/0x6310000F
135    22:02:07.161  08/21/13  Sev=Info/5               CM/0x63100025
136    22:02:07.211  08/21/13  Sev=Info/6               CM/0x63100046
137    22:02:07.211  08/21/13  Sev=Info/4               IKE/0x63000001
138    22:02:07.661  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
139    22:02:07.661  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
140    22:02:07.661  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
141    22:02:07.661  08/21/13  Sev=Info/4               IPSEC/0x6370000A
142    22:05:29.019  08/21/13  Sev=Info/4               PPP/0x63200015
Processing enumerate phone book entries command
143    22:05:29.029  08/21/13  Sev=Info/4               PPP/0x6320000D
Retrieved 1 dial entries
144    22:13:29.345  08/21/13  Sev=Info/4               CM/0x63100002
145    22:13:29.385  08/21/13  Sev=Info/4               CM/0x63100004
146    22:13:29.385  08/21/13  Sev=Info/4               CM/0x63100024
147    22:13:29.545  08/21/13  Sev=Info/6               IKE/0x6300003B
148    22:13:29.575  08/21/13  Sev=Info/4               IKE/0x63000013
149    22:13:29.675  08/21/13  Sev=Info/4               IPSEC/0x63700008
150    22:13:29.675  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
151    22:13:29.825  08/21/13  Sev=Info/5               IKE/0x6300002F
152    22:13:29.825  08/21/13  Sev=Info/4               IKE/0x63000014
153    22:13:29.825  08/21/13  Sev=Info/5               IKE/0x63000001
154    22:13:29.825  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports XAUTH
155    22:13:29.825  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports DPD
156    22:13:29.825  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports NAT-T
157    22:13:29.825  08/21/13  Sev=Info/5               IKE/0x63000001
158    22:13:29.825  08/21/13  Sev=Info/5               IKE/0x63000001
159    22:13:29.835  08/21/13  Sev=Info/6               IKE/0x63000001
160    22:13:29.835  08/21/13  Sev=Info/4               IKE/0x63000013
161    22:13:29.845  08/21/13  Sev=Info/6               IKE/0x63000055
162    22:13:29.845  08/21/13  Sev=Info/4               IKE/0x63000083
IKE Port in use - Local Port =  0xDAE2, Remote Port = 0x1194
163    22:13:29.845  08/21/13  Sev=Info/5               IKE/0x63000072
164    22:13:29.845  08/21/13  Sev=Info/4               CM/0x6310000E
165    22:13:30.085  08/21/13  Sev=Info/5               IKE/0x6300002F
166    22:13:30.085  08/21/13  Sev=Info/4               IKE/0x63000014
167    22:13:30.085  08/21/13  Sev=Info/4               CM/0x6310001B
168    22:13:30.085  08/21/13  Sev=Info/4               IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=FEBCD71A4568C80A R_Cookie=9848570799C15106) reason = DEL_REASON_LOAD_BALANCING
169    22:13:30.085  08/21/13  Sev=Info/4               IKE/0x63000013
170    22:13:30.695  08/21/13  Sev=Info/4               IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=FEBCD71A4568C80A R_Cookie=9848570799C15106) reason = DEL_REASON_LOAD_BALANCING
171    22:13:30.695  08/21/13  Sev=Info/4               CM/0x63100014
172    22:13:30.695  08/21/13  Sev=Info/4               CM/0x63100010
173    22:13:30.695  08/21/13  Sev=Info/4               CM/0x63100024
174    22:13:30.695  08/21/13  Sev=Info/6               IKE/0x6300003B
175    22:13:30.715  08/21/13  Sev=Info/4               IKE/0x63000013
176    22:13:30.965  08/21/13  Sev=Info/5               IKE/0x6300002F
177    22:13:30.965  08/21/13  Sev=Info/4               IKE/0x63000014
178    22:13:30.995  08/21/13  Sev=Info/5               IKE/0x63000001
179    22:13:30.995  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports XAUTH
180    22:13:30.995  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports DPD
181    22:13:30.995  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports NAT-T
182    22:13:30.995  08/21/13  Sev=Info/5               IKE/0x63000001
183    22:13:30.995  08/21/13  Sev=Info/5               IKE/0x63000001
184    22:13:31.005  08/21/13  Sev=Info/6               IKE/0x63000001
185    22:13:31.005  08/21/13  Sev=Info/4               IKE/0x63000013
186    22:13:31.005  08/21/13  Sev=Info/6               IKE/0x63000055
187    22:13:31.005  08/21/13  Sev=Info/4               IKE/0x63000083
IKE Port in use - Local Port =  0xDAE5, Remote Port = 0x1194
188    22:13:31.005  08/21/13  Sev=Info/5               IKE/0x63000072
189    22:13:31.005  08/21/13  Sev=Info/4               CM/0x6310000E
190    22:13:31.255  08/21/13  Sev=Info/5               IKE/0x6300002F
191    22:13:31.255  08/21/13  Sev=Info/4               IKE/0x63000014
192    22:13:31.255  08/21/13  Sev=Info/4               CM/0x63100015
193    22:13:33.015  08/21/13  Sev=Info/4               CM/0x63100017
194    22:13:33.015  08/21/13  Sev=Info/4               IKE/0x63000013
195    22:13:33.015  08/21/13  Sev=Info/4               CM/0x63100018
User does not provide any authentication data
196    22:13:33.015  08/21/13  Sev=Info/4               IKE/0x63000001
197    22:13:33.015  08/21/13  Sev=Info/4               IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=6857263F5BACEAA8 R_Cookie=1175A58126B6501D) reason = DEL_REASON_RESET_SADB
198    22:13:33.015  08/21/13  Sev=Info/4               IKE/0x63000013
199    22:13:33.015  08/21/13  Sev=Info/4               IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=6857263F5BACEAA8 R_Cookie=1175A58126B6501D) reason = DEL_REASON_RESET_SADB
200    22:13:33.015  08/21/13  Sev=Info/5               CM/0x63100025
201    22:13:33.025  08/21/13  Sev=Info/6               CM/0x63100046
202    22:13:33.235  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
203    22:13:33.235  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
204    22:13:33.235  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
205    22:13:33.235  08/21/13  Sev=Info/4               IPSEC/0x6370000A
206    22:13:34.635  08/21/13  Sev=Info/4               CM/0x63100002
207    22:13:34.655  08/21/13  Sev=Info/4               CM/0x63100004
208    22:13:34.655  08/21/13  Sev=Info/4               CM/0x63100024
209    22:13:34.655  08/21/13  Sev=Info/6               IKE/0x6300003B
210    22:13:34.675  08/21/13  Sev=Info/4               IKE/0x63000013
211    22:13:34.745  08/21/13  Sev=Info/4               IPSEC/0x63700008
212    22:13:34.745  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
213    22:13:34.935  08/21/13  Sev=Info/5               IKE/0x6300002F
214    22:13:34.935  08/21/13  Sev=Info/4               IKE/0x63000014
215    22:13:34.935  08/21/13  Sev=Info/5               IKE/0x63000001
216    22:13:34.935  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports XAUTH
217    22:13:34.935  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports DPD
218    22:13:34.935  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports NAT-T
219    22:13:34.935  08/21/13  Sev=Info/5               IKE/0x63000001
220    22:13:34.935  08/21/13  Sev=Info/5               IKE/0x63000001
221    22:13:34.935  08/21/13  Sev=Info/6               IKE/0x63000001
222    22:13:34.935  08/21/13  Sev=Info/4               IKE/0x63000013
223    22:13:34.935  08/21/13  Sev=Info/6               IKE/0x63000055
224    22:13:34.935  08/21/13  Sev=Info/4               IKE/0x63000083
IKE Port in use - Local Port =  0xDAE8, Remote Port = 0x1194
225    22:13:34.935  08/21/13  Sev=Info/5               IKE/0x63000072
226    22:13:34.935  08/21/13  Sev=Info/4               CM/0x6310000E
227    22:13:35.175  08/21/13  Sev=Info/5               IKE/0x6300002F
228    22:13:35.175  08/21/13  Sev=Info/4               IKE/0x63000014
229    22:13:35.175  08/21/13  Sev=Info/4               CM/0x6310001B
230    22:13:35.175  08/21/13  Sev=Info/4               IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=21088E1193F33444 R_Cookie=FA5CD3B5FD01EF35) reason = DEL_REASON_LOAD_BALANCING
231    22:13:35.175  08/21/13  Sev=Info/4               IKE/0x63000013
232    22:13:35.755  08/21/13  Sev=Info/4               IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=21088E1193F33444 R_Cookie=FA5CD3B5FD01EF35) reason = DEL_REASON_LOAD_BALANCING
233    22:13:35.755  08/21/13  Sev=Info/4               CM/0x63100014
234    22:13:35.755  08/21/13  Sev=Info/4               CM/0x63100010
235    22:13:35.755  08/21/13  Sev=Info/4               CM/0x63100024
236    22:13:35.755  08/21/13  Sev=Info/6               IKE/0x6300003B
237    22:13:35.775  08/21/13  Sev=Info/4               IKE/0x63000013
238    22:13:36.015  08/21/13  Sev=Info/5               IKE/0x6300002F
239    22:13:36.015  08/21/13  Sev=Info/4               IKE/0x63000014
240    22:13:36.015  08/21/13  Sev=Info/5               IKE/0x63000001
241    22:13:36.015  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports XAUTH
242    22:13:36.015  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports DPD
243    22:13:36.015  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports NAT-T
244    22:13:36.015  08/21/13  Sev=Info/5               IKE/0x63000001
245    22:13:36.015  08/21/13  Sev=Info/5               IKE/0x63000001
246    22:13:36.025  08/21/13  Sev=Info/6               IKE/0x63000001
247    22:13:36.025  08/21/13  Sev=Info/4               IKE/0x63000013
248    22:13:36.025  08/21/13  Sev=Info/6               IKE/0x63000055
249    22:13:36.025  08/21/13  Sev=Info/4               IKE/0x63000083
IKE Port in use - Local Port =  0xDAEB, Remote Port = 0x1194
250    22:13:36.025  08/21/13  Sev=Info/5               IKE/0x63000072
251    22:13:36.025  08/21/13  Sev=Info/4               CM/0x6310000E
252    22:13:36.275  08/21/13  Sev=Info/5               IKE/0x6300002F
253    22:13:36.275  08/21/13  Sev=Info/4               IKE/0x63000014
254    22:13:36.275  08/21/13  Sev=Info/4               CM/0x63100015
255    22:13:46.465  08/21/13  Sev=Info/6               IKE/0x63000055
256    22:13:49.865  08/21/13  Sev=Info/4               CM/0x63100017
257    22:13:49.865  08/21/13  Sev=Info/4               IKE/0x63000013
258    22:13:49.865  08/21/13  Sev=Info/4               CM/0x63100018
259    22:13:49.865  08/21/13  Sev=Info/4               IKE/0x63000001
260    22:13:49.865  08/21/13  Sev=Info/4               IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=DFAAD9AF41FE9FD6 R_Cookie=7F4F98E882EC7309) reason = DEL_REASON_RESET_SADB
261    22:13:49.865  08/21/13  Sev=Info/4               IKE/0x63000013
262    22:13:49.865  08/21/13  Sev=Info/4               IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=DFAAD9AF41FE9FD6 R_Cookie=7F4F98E882EC7309) reason = DEL_REASON_RESET_SADB
263    22:13:49.865  08/21/13  Sev=Info/5               CM/0x63100025
264    22:13:49.875  08/21/13  Sev=Info/6               CM/0x63100046
265    22:13:50.005  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
266    22:13:50.005  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
267    22:13:50.005  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
268    22:13:50.005  08/21/13  Sev=Info/4               IPSEC/0x6370000A
269    22:31:36.291  08/21/13  Sev=Info/4               CM/0x63100002
270    22:31:36.951  08/21/13  Sev=Info/4               CM/0x63100004
271    22:31:36.951  08/21/13  Sev=Info/4               CM/0x63100024
272    22:31:37.321  08/21/13  Sev=Info/6               IKE/0x6300003B
273    22:31:37.341  08/21/13  Sev=Info/4               IKE/0x63000013
274    22:31:37.341  08/21/13  Sev=Info/4               IPSEC/0x63700008
275    22:31:37.341  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
276    22:31:37.591  08/21/13  Sev=Info/5               IKE/0x6300002F
277    22:31:37.591  08/21/13  Sev=Info/4               IKE/0x63000014
278    22:31:37.591  08/21/13  Sev=Info/5               IKE/0x63000001
279    22:31:37.591  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports XAUTH
280    22:31:37.591  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports DPD
281    22:31:37.591  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports NAT-T
282    22:31:37.591  08/21/13  Sev=Info/5               IKE/0x63000001
283    22:31:37.591  08/21/13  Sev=Info/5               IKE/0x63000001
284    22:31:37.601  08/21/13  Sev=Info/6               IKE/0x63000001
285    22:31:37.601  08/21/13  Sev=Info/4               IKE/0x63000013
286    22:31:37.601  08/21/13  Sev=Info/6               IKE/0x63000055
287    22:31:37.601  08/21/13  Sev=Info/4               IKE/0x63000083
IKE Port in use - Local Port =  0xC705, Remote Port = 0x1194
288    22:31:37.601  08/21/13  Sev=Info/5               IKE/0x63000072
289    22:31:37.601  08/21/13  Sev=Info/4               CM/0x6310000E
290    22:31:37.851  08/21/13  Sev=Info/5               IKE/0x6300002F
291    22:31:37.851  08/21/13  Sev=Info/4               IKE/0x63000014
292    22:31:37.851  08/21/13  Sev=Info/4               CM/0x6310001B
293    22:31:37.851  08/21/13  Sev=Info/4               IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=20362EA202221F2A R_Cookie=1D53C01FE0F035F1) reason = DEL_REASON_LOAD_BALANCING
294    22:31:37.851  08/21/13  Sev=Info/4               IKE/0x63000013
295    22:31:38.671  08/21/13  Sev=Info/4               IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=20362EA202221F2A R_Cookie=1D53C01FE0F035F1) reason = DEL_REASON_LOAD_BALANCING
296    22:31:38.671  08/21/13  Sev=Info/4               CM/0x63100014
297    22:31:38.671  08/21/13  Sev=Info/4               CM/0x63100010
298    22:31:38.671  08/21/13  Sev=Info/4               CM/0x63100024
299    22:31:38.671  08/21/13  Sev=Info/6               IKE/0x6300003B
300    22:31:38.691  08/21/13  Sev=Info/4               IKE/0x63000013
301    22:31:38.941  08/21/13  Sev=Info/5               IKE/0x6300002F
302    22:31:38.941  08/21/13  Sev=Info/4               IKE/0x63000014
303    22:31:38.941  08/21/13  Sev=Info/5               IKE/0x63000001
304    22:31:38.941  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports XAUTH
305    22:31:38.941  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports DPD
306    22:31:38.941  08/21/13  Sev=Info/5               IKE/0x63000001
Peer supports NAT-T
307    22:31:38.941  08/21/13  Sev=Info/5               IKE/0x63000001
308    22:31:38.941  08/21/13  Sev=Info/5               IKE/0x63000001
309    22:31:38.951  08/21/13  Sev=Info/6               IKE/0x63000001
310    22:31:38.951  08/21/13  Sev=Info/4               IKE/0x63000013
311    22:31:38.951  08/21/13  Sev=Info/6               IKE/0x63000055
312    22:31:38.951  08/21/13  Sev=Info/4               IKE/0x63000083
IKE Port in use - Local Port =  0xC708, Remote Port = 0x1194
313    22:31:38.951  08/21/13  Sev=Info/5               IKE/0x63000072
314    22:31:38.951  08/21/13  Sev=Info/4               CM/0x6310000E
315    22:31:39.201  08/21/13  Sev=Info/5               IKE/0x6300002F
316    22:31:39.201  08/21/13  Sev=Info/4               IKE/0x63000014
317    22:31:39.201  08/21/13  Sev=Info/4               CM/0x63100015
318    22:31:40.381  08/21/13  Sev=Info/4               CM/0x63100017
319    22:31:40.381  08/21/13  Sev=Info/4               IKE/0x63000013
320    22:31:40.381  08/21/13  Sev=Info/4               CM/0x63100018
321    22:31:40.381  08/21/13  Sev=Info/4               IKE/0x63000001
322    22:31:40.381  08/21/13  Sev=Info/4               IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=51D221E08BE90CB5 R_Cookie=06B2572995AB291A) reason = DEL_REASON_RESET_SADB
323    22:31:40.381  08/21/13  Sev=Info/4               IKE/0x63000013
324    22:31:40.381  08/21/13  Sev=Info/4               IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=51D221E08BE90CB5 R_Cookie=06B2572995AB291A) reason = DEL_REASON_RESET_SADB
325    22:31:40.381  08/21/13  Sev=Info/5               CM/0x63100025
326    22:31:40.381  08/21/13  Sev=Info/6               CM/0x63100046
327    22:31:40.691  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
328    22:31:40.691  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
329    22:31:40.691  08/21/13  Sev=Info/4               IPSEC/0x63700014
Deleted all keys
330    22:31:40.691  08/21/13  Sev=Info/4               IPSEC/0x6370000A
194
