RDP Access problem
Hi ,
i am using  Cisco ASA5510  Firewall  on  my  network  at the distrubution  Layer  . The  Private IP Address is  in the network  for  Users  and PAT  is  use.
I have  a  client   who has  configured the RDP on port2000. when  the Users  behind  the Firewall  in my Network  tried RDP  it does not work  it shows  configuring  remote Desktop only. i am  able to telnet  the Client  said server  with port 2000  but  unable  RDP.
Is  any changes  required  on my firewall  as a tesult  the RDP works.
Please advice.
Saroj
Silver
RDP Access problem
Saroj,
You most likely want to move you're question over to this forum for your answer.
https://supportforums.cisco.com/community/netpro/security/firewall
Jasbryan
Silver
RDP Access problem
Hi Saroj,
Per Jason's suggestion, I have moved your question into the firewall area so you do not need to repost.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
RDP Access problem
Hello Saroj,
Please attach the ASA configuration to the post so I can review it.
Thanks.
Re: RDP Access problem
Please find the ASA Configuration.
Saroj
Here is the packet-tracer we used yesterday to troubleshoot this:
Netlink-OS-ASA# packet-tracer input inside tcp 172.16.48.213 1025 74.94.242.13$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access_in_1 in interface inside
access-list inside_access_in_1 extended permit ip any any
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: inspect-skinny
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect skinny
service-policy global_policy global
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (inside) 1 Block_FromASA_ThroughUntangle1 255.255.255.192
  match ip inside Block_FromASA_ThroughUntangle1 255.255.255.192 outside any
    dynamic translation to pool 1 (122.168.191.66 Re: RDP Access problem  through ASA5510 FW)
    translate_hits = 59925, untranslate_hits = 345
Dynamic translate 172.16.48.213/1025 to 122.168.191.66/29284 using netmask 255.255.255.255
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 9
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside_access_out out interface outside
access-list outside_access_out extended permit ip any any
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 59535332, packet dispatched to next module
Phase: 12
Type: ROUTE-LOOKUP
Subtype: output and adjacency
Result: ALLOW
Config:
found next-hop 122.168.191.65 using egress ifc outside
adjacency Active
next-hop mac address 0019.2f8e.c639 hits 29742
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
Please create some captures to check if the RDP server is responding to the client request!
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
I have configured the packet capture but unable to find the RDP Server IP in the Capture packet List which is 74.94.242.139
Netlink-OS-ASA(config)# show capture testcap count 20
1145 packets captured
1: 21:01:58.142784 172.16.63.1.22 > 172.16.51.10.49245: P 2967950329:2967950397(68) ack 2868729768 win 8192
2: 21:01:58.142845 76.187.139.64.43075 > 172.16.51.10.14106: udp 1402
3: 21:01:58.143028 172.16.51.10.49245 > 172.16.63.1.22: . ack 2967950397 win 65535
4: 21:01:58.143455 76.187.139.64.43075 > 172.16.51.10.14106: udp 1402
5: 21:01:58.144508 76.127.90.119.52843 > 172.16.51.10.14106: udp 1438
6: 21:01:58.144523 209.104.131.20.443 > 172.16.50.168.52716: udp 85
7: 21:01:58.144630 209.104.131.20.443 > 172.16.51.10.1117: udp 85
8: 21:01:58.146217 172.16.51.10.56443 > 199.71.245.17.443: P 4023407154:4023407192(38) ack 2968440731 win 65535
9: 21:01:58.146766 208.86.251.15.80 > 172.16.51.10.53612: S 191863448:191863448(0) ack 1450255578 win 65535 172.16.48.72.3389: . ack 2709156126 win 258
Here is what you need to do:
access-list capin permit tcp host rdp_client_private_ip host server_outside eq 2000
access-list capin permit tcp  host server_outside eq 2000 host rdp_client_private_ip
access-list capout permit tcp host rdp_client_public_ip host server_outside eq 2000
access-list capout permit tcp host server_outside eq 2000 host rdp_client_public_ip
capture capin access-list capin interface inside
capture capout access-list capout interface outside
Julio
As per your instruction I have configured on the ASA the following command to capture packet but no result.
Showing 0 packet captured while trying with RDP On port 2000 ,
Saroj
392
