Really Need Some Help With IOS Firewall On 2911 Router With CME
I have a 2911 Router with IOS Security and Voice enabled and we are using CME 8.6.  I am using a built-in Anyconnect VPN on 3 phones that are for remote users and thus I needed to enable security zones on the router which works because the remote phones will boot up, get their phone configs and I am able to call those remote phones from an outside line.
The issue I am having is that when I try to dial a remote phone connected via the VPN through port g0/0 from and internal office phone, i.e., NOT involving the PSTN then there is no audio.  It's as if no audio is going back and forth.  When I take off the security zones from the virtual-template interface and the g0/0 interface then the audio works great and I can reach the phone from internal as I am supposed to.
Could someone take a peek at my security config and see why audio would not be traveling through the VPN when I have my security zones turned on?
clock timezone PST -8 0
clock summer-time PST recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.8.1 192.168.8.19
ip dhcp pool owhvoip
 network 192.168.8.0 255.255.248.0
 default-router 192.168.8.1
 option 150 ip 192.168.8.1
 lease 30
isdn switch-type primary-ni
crypto pki server cme_root
 database level complete
 grant auto
 lifetime certificate 7305
 lifetime ca-certificate 7305
crypto pki trustpoint cme_root
 enrollment url http://192.168.8.1:80
 revocation-check none
 rsakeypair cme_root
crypto pki trustpoint cme_cert
crypto pki trustpoint TP-self-signed-2736782807
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2736782807
 rsakeypair TP-self-signed-2736782807
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 vpn-group 1
  vpn-gateway 1 https://66.111.111.111/SSLVPNphone
  vpn-trustpoint 1 trustpoint cme_cert leaf
 vpn-profile 1
  host-id-check disable
voice class codec 1
 codec preference 1 g711ulaw
voice class custom-cptone jointone
 dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class custom-cptone leavetone
 dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice translation-rule 1
 rule 1 /9400/ /502/
 rule 2 /9405/ /215/
 rule 3 /9410/ /500/
voice translation-rule 2
 rule 1 /.*/ /541999999/
voice translation-rule 100
 rule 1 /^9/ // type any unknown plan any isdn
voice translation-profile Inbound_Calls_To_CUE
 translate called 1
voice translation-profile InternationalType
 translate called 100
voice translation-profile Local-CLID
 translate calling 2
license udi pid CISCO2911/K9 sn FTX1641AHX3
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
username routeradmin password 7 091649040910450B41
username cmeadmin privilege 15 password 7 03104803040E375F5E4D5D51
redundancy
controller T1 0/0/0
 cablelength long 0db
 pri-group timeslots 1-12,24
class-map type inspect match-any sslvpn
 match protocol tcp
 match protocol udp
 match protocol icmp
class-map type inspect match-all router-access
 match access-group name router-access
policy-map type inspect firewall-policy
 class type inspect sslvpn
  inspect
 class class-default
  drop
policy-map type inspect outside-to-router-policy
 class type inspect router-access
  inspect
 class class-default
  drop
zone security trusted
zone security internet
zone-pair security trusted-to-internet source trusted destination internet
 service-policy type inspect firewall-policy
zone-pair security untrusted-to-trusted source internet destination trusted
 service-policy type inspect outside-to-router-policy
interface Loopback0
 ip address 192.168.17.1 255.255.248.0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Internet
 ip address dhcp
 no ip redirects
 no ip proxy-arp
 zone-member security internet
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.8.1 255.255.248.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:23
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
interface Integrated-Service-Engine1/0
 ip unnumbered Loopback0
 service-module ip address 192.168.17.2 255.255.248.0
 !Application: CUE Running on NME
 service-module ip default-gateway 192.168.17.1
 no keepalive
interface Virtual-Template1
 ip unnumbered GigabitEthernet0/0
 zone-member security trusted
ip local pool SSLVPNPhone_pool 192.168.9.1 192.168.9.5
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/cme-gui-8.6.0
ip route 192.168.17.2 255.255.255.255 Integrated-Service-Engine1/0
ip access-list extended router-access
 permit tcp any host 66.111.111.111 eq 443
tftp-server flash:apps31.9-3-1ES26.sbn
control-plane
voice-port 0/0/0:23
voice-port 0/3/0
voice-port 0/3/1
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 192.168.8.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/1
 associate ccm 1 priority 1
 associate profile 1 register CME-CONF
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 4
 associate application SCCP
dial-peer voice 500 voip
 destination-pattern 5..
 session protocol sipv2
 session target ipv4:192.168.17.2
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 10 pots
 description Incoming Calls To AA
 translation-profile incoming Inbound_Calls_To_CUE
 incoming called-number .
 port 0/0/0:23
dial-peer voice 20 pots
 description local 10 digit dialing
 translation-profile outgoing Local-CLID
 destination-pattern 9[2-9].........
 port 0/0/0:23
 forward-digits 10
dial-peer voice 30 pots
 description long distance dialing
 destination-pattern 91..........
 port 0/0/0:23
 forward-digits 11
dial-peer voice 40 pots
 description 911
 destination-pattern 911
 port 0/0/0:23
 forward-digits all
dial-peer voice 45 pots
 description 9911
 destination-pattern 9911
 port 0/0/0:23
 forward-digits 3
dial-peer voice 50 pots
 description international dialing
 translation-profile outgoing InternationalType
 destination-pattern 9T
 port 0/0/0:23
dial-peer voice 650 pots
 huntstop
 destination-pattern 650
 fax rate disable
 port 0/3/0
gatekeeper
 shutdown
telephony-service
 protocol mode ipv4
 sdspfarm units 5
 sdspfarm tag 1 CME-CONF
 conference hardware
 moh-file-buffer 90
 no auto-reg-ephone
 authentication credential cmeadmin tshbavsp$$4
 max-ephones 50
 max-dn 200
 ip source-address 192.168.8.1 port 2000
 service dnis dir-lookup
 timeouts transfer-recall 30
 system message Oregon's Wild Harvest
 url services http://192.168.17.2/voiceview/common/login.do
 url authentication http://192.168.8.1/CCMCIP/authenticate.asp
 cnf-file location flash:
 cnf-file perphone
 load 7931 SCCP31.9-3-1SR4-1S.loads
 load 7936 cmterm_7936.3-3-21-0.bin
 load 7942 SCCP42.9-3-1SR4-1S.loads
 load 7962 SCCP42.9-4-2-1S.loads
 time-zone 5
 time-format 24
 voicemail 500
 max-conferences 8 gain -6
 call-park system application
 call-forward pattern .T
 moh moh.wav
 web admin system name cmeadmin secret 5 $1$60ro$u.0r/cno/OD2JmtvPq4w9.
 dn-webedit
 transfer-digit-collect orig-call
 transfer-system full-consult
 transfer-pattern .T
 fac standard
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
 softkeys connected  Hold Park Confrn Trnsfer Endcall ConfList TrnsfVM
 button-layout 7931 2
ephone-template  2
 softkeys idle  Dnd Gpickup Pickup Mobility
 softkeys connected  Hold Park Confrn Mobility Trnsfer TrnsfVM
ephone-dn  1  dual-line
 number 200
 label Lisa
 name Lisa Ziomkowsky
 call-forward busy 500
 call-forward noan 500 timeout 10
ephone-dn  2  dual-line
 number 201
 label Dylan
 name Dylan Elmer
 call-forward noan 500 timeout 12
ephone-dn  3  dual-line
 number 202
 label Kimberly
 name Kimberly Krueger
ephone-dn  4  dual-line
 number 203
 label Randy
 name Randy Buresh
 mobility
 snr calling-number local
 snr 915035042317 delay 5 timeout 15 cfwd-noan 500
ephone-dn  5  dual-line
 number 204
 label Mark
 name Mark McBride
ephone-dn  6  dual-line
 number 205
 label Susan
 name Susan Sundin
ephone-dn  7  dual-line
 number 206
 label Rebecca
 name Rebecca Vaught
ephone-dn  8  dual-line
 number 207
 label Ronnda
 name Ronnda Daniels
ephone-dn  9  dual-line
 number 208
 label Matthew
 name Matthew Creswell
ephone-dn  10  dual-line
 number 209
 label Nate
 name Nate Couture
ephone-dn  11  dual-line
 number 210
 label Sarah
 name Sarah Smith
ephone-dn  12  dual-line
 number 211
 label Janis
 name Janis McFerren
ephone-dn  13  dual-line
 number 212
 label Val
 name Val McBride
ephone-dn  14  dual-line
 number 213
 label Shorty
 name Arlene Haugen
ephone-dn  15  dual-line
 number 214
 label Ruta
 name Ruta Wells
ephone-dn  16  dual-line
 number 215
 label 5415489405
 name OWH Sales
ephone-dn  17  dual-line
 number 216
ephone-dn  18  dual-line
 number 217
ephone-dn  19  dual-line
 number 218
ephone-dn  20  dual-line
 number 219
ephone-dn  21  dual-line
 number 220
ephone-dn  22  dual-line
 number 221
ephone-dn  23  dual-line
 number 222
 label Pam
 name Pam Buresh
ephone-dn  24  dual-line
 number 223
ephone-dn  25  dual-line
 number 224
ephone-dn  26  dual-line
 number 225
 label Elaine
 name Elaine Mahan
ephone-dn  27  octo-line
 number 250
 label Shipping
 name Shipping
ephone-dn  28  dual-line
 number 251
 label Eli
 name Eli Nourse
ephone-dn  29  dual-line
 number 252
ephone-dn  30  dual-line
 number 253
ephone-dn  31  octo-line
 number 100
 label Customer Service
 name Customer Service
ephone-dn  32  octo-line
 number 101
 label Sales
 name Sales
 call-forward busy 214
 call-forward noan 214 timeout 12
ephone-dn  33  dual-line
 number 260
 label Conference Room
 name Conference Room
 call-forward busy 100
 call-forward noan 100 timeout 12
ephone-dn  100
 number 300
 park-slot timeout 20 limit 2 recall
 description Park Slot For All Company
ephone-dn  101
 number 301
 description Park Slot for All Company
ephone-dn  102
 number 302
ephone-dn  103
 number 700
 name All Company Paging
 paging ip 239.1.1.10 port 2000
ephone-dn  104
 number 8000...
 mwi on
ephone-dn  105
 number 8001...
 mwi off
ephone-dn  106  octo-line
 number A00
 description ad-hoc conferencing
 conference ad-hoc
ephone-dn  107  octo-line
 number A01
 conference ad-hoc
ephone-dn  108  octo-line
 number A02
 conference ad-hoc
ephone  1
 device-security-mode none
 mac-address 001F.CA34.88AE
 ephone-template 1
 max-calls-per-button 2
 paging-dn 103
 type 7931
 button  1:2 2:31
ephone  2
 mac-address 001F.CA34.8A03
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:12
ephone  3
 mac-address 001F.CA34.898B
 ephone-template 1
 paging-dn 103
 type 7931
ephone  4
 mac-address 001F.CA34.893F
 ephone-template 1
 paging-dn 103
 type 7931
ephone  5
 mac-address 001F.CA34.8A71
 ephone-template 1
 username "susan"
 paging-dn 103
 type 7931
 button  1:6
ephone  6
 mac-address 001F.CA34.8871
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:7 2:31 3:32
ephone  7
 mac-address 001F.CA34.8998
 ephone-template 1
 username "matthew"
 paging-dn 103
 type 7931
 button  1:9
ephone  8
 mac-address 001F.CA36.8787
 ephone-template 1
 username "nate"
 paging-dn 103
 type 7931
 button  1:10
ephone  9
 mac-address 001F.CA34.8805
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:5
ephone  10
 mac-address 001F.CA34.880C
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:14
ephone  11
 mac-address 001F.CA34.8935
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:3
ephone  12
 mac-address 001F.CA34.8995
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:8 2:31
ephone  13
 mac-address 0021.5504.1796
 ephone-template 2
 paging-dn 103
 type 7931
 button  1:4
ephone  14
 mac-address 001F.CA34.88F7
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:23
ephone  15
 mac-address 001F.CA34.8894
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:26
ephone  16
 mac-address 001F.CA34.8869
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:28 2:27
ephone  17
 mac-address 001F.CA34.885F
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:11
ephone  18
 mac-address 001F.CA34.893C
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:27
ephone  19
 mac-address 001F.CA34.8873
 ephone-template 1
 paging-dn 103
 type 7931
 button  1:27
ephone  20
 mac-address A456.3040.B7DD
 paging-dn 103
 type 7942
 vpn-group 1
 vpn-profile 1
 button  1:13
ephone  21
 mac-address A456.30BA.5474
 paging-dn 103
 type 7942
 vpn-group 1
 vpn-profile 1
 button  1:15 2:16 3:32
ephone  22
 mac-address A456.3040.B72E
 paging-dn 103
 type 7942
 vpn-group 1
 vpn-profile 1
 button  1:1
ephone  23
 mac-address 00E0.75F3.D1D9
 paging-dn 103
 type 7936
 button  1:33
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
line vty 0 4
 transport input all
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server 216.228.192.69
webvpn gateway sslvpn_gw
 ip address 66.111.111.111 port 443
 ssl encryption 3des-sha1 aes-sha1
 ssl trustpoint cme_cert
 inservice
webvpn context sslvpn_context
 ssl authenticate verify all
 policy group SSLVPNphone
   functions svc-enabled
   hide-url-bar
   svc address-pool "SSLVPNPhone_pool" netmask 255.255.248.0
   svc default-domain "bendbroadband.com"
 virtual-template 1
 default-group-policy SSLVPNphone
 gateway sslvpn_gw domain SSLVPNphone
 authentication certificate
 ca trustpoint cme_root
 inservice
end
Everyone's tags (1)
VIP Green
I think your ACL could be the
I think your ACL could be the culprit.
Would you be able to change the entry to permit ip any any (just for testing purpose) and then test to see if the calls function properly.  If they work fine then we know that we need to open som ports there.
Please remember to select a correct answer and rate helpful posts
-- Please remember to rate and select a correct answer
Hello. I tried that and no
Hello. I tried that and no luck. I'm wondering if that interface is the issue or is it another one? The remote phones which are connected via vpn will ring but no audio goes back and forth.
VIP Green
You could try to add the
You could try to add the permit IP any any to the trusted zone policy and see if that sorts things out.
123
