Recommendation required ASA/ASDM software
Dear Experts,
I am going to have an installation for ASA 5520 with AIP-SSM10.
I will be doing site-to-site VPN, Remote Access VPN and also SSL VPN on ASA.
I want suggestions related to the ASA version. After reading release notes for version 8 i am thinking about version 8.0 but I am not sure about the stability of version 8.0
can someone advice me which ASA version I should go for it.
Thanks a lot in advance
Re: Recommendation required ASA/ASDM software
I have deployed version 8.0(3) on quite a few ASA and PIX devices without any problems. I don't see a clear reason why you shouldn't use version 8 of the code. Just make sure to read the release notes to ensure that there are not any bugs related to your organization's setup.
Actually i am going to the following on the firewall.
1. 10 Site to site VPN from Routers to ASA
2. 10 SSL Vpn connection to ASA
3. 200+ remote access VPN on ASA.
4. INLINE IPS using AIP-SSM-10 on ASA
5. Active Directory integration for remote access VPN and SSL VPN.
6. DHCP pool on ASA.
7. Lot of different kinds of Natting.
Actually I am also looking the advice if anyone setup this kind of scenario or near to this kind. I really don't want to play first and reach to the stable configuration. I am trying to start with the most recommend ASA/ASDM versions.
BTW how did you find ASDM 6.0 for impmentation & also day to day management?.
I like the ASDM for installation and management for the ASA/PIX devices. Version 6 has worked well for me. The VPN wizards are helpful in setting up both SSL and IPSec remote access VPNs as well as Site to Site connections. I have setup similiar secenarios for clients in the past, so there isn;t anything really crazy in your list. The biggest thing to do is to make sure that you size the device properly for your needs.
202
