Recovery process for a PIX515e failure
I had a PIX515e fail on me last week.  I had to jump through some hoops.  I had to get a replacement and then reload the config. When I reloaded the config a series of commands were omitted. NAT’s and Crypto’s mainly.  I think this was because I had an enhanced security key installed on it and the key was not initially installed.
Post I am trying to learn from this so in the event I have another failure I can recover quicker.  I think the recovery process should be:
1.       Install the correct IOS
2.       Install the correct license keys
3.       TFTP the config on to the PIX
Any comments would be appreciated.  Thanks.
1 REPLY
Hall of Fame Super Blue
Re: Recovery process for a PIX515e failure
Presumably the crypto commands were because you were referring to 3DES for example. Not sure about the NAT commands.
Anyway, yes that looks like a good recovery process in the sense of making sure the correct key is there before trying to copy back the config. Have you thought about running an active/standby pair so if one fails it simply fails over to the other one ?
Jon
161
